Decode a JSON geometry
4465
09-08-2011 07:12 AM
EstherColero
I'm looking for a way to store the Graphics of the DrawWidget in a database and load them in a next session.
I thing that I need to save the geometry and the symbol for each Graphic, and probably the best way is use JSON.encode and JSON.decode
http://help.arcgis.com/en/webapi/flex/apiref/com/esri/ags/utils/JSON.html
I can transform a geometry to JSON and the JSON string to a Object type but, How can I create a Geometry type from JSON string? I'm sure that there is something in the API (probably geometryService wrapper use that) but I can't find it.
And if you know how to create a Symbol (SimpleMarkerSymbol, SimpleLineSymbol....) or a Graphic from JSON using API or if you have a code snippet it could be very useful for me 🙂 Any help is welcome.
Thank you in advance.
Regards
Esther
IvanBespalov
Hi, FeatureSet is Array of Graphics.
FeatureSet () Constructor
public function FeatureSet(features:Array = null)
where
features property
features:Array
Array of graphic features.
See also
com.esri.ags.Graphic
Each feature in features array is Graphic. Each Graphic (in JSON) consists of "geometry" (in JSON) and "attributes" (in JSON) smthing like:
"features" : [
      "geometry" : {
        "x" : -178.24479999999991,
        "y" : 50.012500000000045
      "attributes" : {
        "objectid" : 3745682,
        "datetime" : 1272210710000,
        "depth" : 31.100000000000001,
        "eqid" : "2010vma5",
        "latitude" : 50.012500000000003,
        "longitude" : -178.2448,
        "magnitude" : 4.7999999999999998,
        "numstations" : 112,
        "region" : "Andreanof Islands, Aleutian Islands, Alaska",
        "source" : "us",
        "version" : "Q"
      "geometry" : {
        "x" : -72.865099999999927,
        "y" : -37.486599999999953
      "attributes" : {
        "objectid" : 3745685,
        "datetime" : 1272210142999,
        "depth" : 40.600000000000001,
        "eqid" : "2010vma4",
        "latitude" : -37.486600000000003,
        "longitude" : -72.865099999999998,
        "magnitude" : 4.9000000000000004,
        "numstations" : 58,
        "region" : "Bio-Bio, Chile",
        "source" : "us",
        "version" : "7"
com.esri.ags.FeatureSet has public methods:
fromJSON () method
public static function fromJSON(json:String):FeatureSet
toJSON () method
public function toJSON():String
Good luck.
EstherColero
Thank you Ivan,
I have try this previuosly, but when I rebuild the FeatureSet there are all Graphics but there is not any geometry or symbol (all them are null)
var pFeatureSet:FeatureSet = null;
var pFeatureSet2:FeatureSet = null;
var arrGraphics:Array = new Array();
var pGraphic:Graphic;
//Store all Graphics in an Array
for (var i:int = 0; i < graphicsLayer.numGraphics; i++)
    pGraphic = Graphic(graphicsLayer.getChildAt(i));
    arrGraphics.push(pGraphic);
//Create FeatureSet
pFeatureSet = new FeatureSet(arrGraphics);
//to JSON
var strJSON:String = pFeatureSet.toJSON();
//toFeatureSet
pFeatureSet2 = FeatureSet.fromJSON(strJSON); //All graphics, but no geometries or symbols
//Now with your example
strJSON = '{"features" : [{"geometry" : {"x" : -178.24479999999991,"y" : 50.012500000000045},"attributes" : {"objectid" : 3745682,"datetime" : 1272210710000,"depth" : 31.100000000000001,"eqid" : "2010vma5","latitude" : 50.012500000000003,"longitude" : -178.2448,"magnitude" : 4.7999999999999998,"numstations" : 112,"region" : "Andreanof Islands, Aleutian Islands, Alaska","source" : "us","version" : "Q"}},{"geometry" : {"x" : -72.865099999999927,"y" : -37.486599999999953},"attributes" : {"objectid" : 3745685,"datetime" : 1272210142999,"depth" : 40.600000000000001,"eqid" : "2010vma4","latitude" : -37.486600000000003,"longitude" : -72.865099999999998,"magnitude" : 4.9000000000000004,"numstations" : 58,"region" : "Bio-Bio, Chile","source" : "us","version" : "7"}}] }';
I am using Flex viewer 2.4. does it work for you?
Regards
Esther
IvanBespalov
Hi.
Reading reference:
fromJSON () method
Convert from JSON to FeatureSet.
Parameters
json:String â?? ArcGIS JSON String
Returns
FeatureSet â?? a new FeatureSet
See also
Input JSON should match this REST response syntax
Try this:
<?xml version="1.0" encoding="utf-8"?>
<s:Application xmlns:fx="http://ns.adobe.com/mxml/2009"
      xmlns:s="library://ns.adobe.com/flex/spark"
      xmlns:esri="http://www.esri.com/2008/ags"
      xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600">
 <s:layout>
  <s:VerticalLayout paddingBottom="6"/>
 </s:layout>
 <fx:Script>
  <![CDATA[
   import com.esri.ags.FeatureSet;
   import com.esri.ags.Graphic;
   import com.esri.ags.events.MapMouseEvent;
   import com.esri.ags.geometry.Geometry;
   import com.esri.ags.geometry.MapPoint;
   import mx.collections.ArrayCollection;
   import mx.utils.StringUtil;
   private var jsonFeatureSet:String = "";
    * Listen map mouse down handler
   protected function myMap_mapMouseDownHandler(event:MapMouseEvent):void
    //var grGeometry:MapPoint = myMap.extent.center;
    var grGeometry:MapPoint = event.mapPoint;
    var grAttributes:Object = new Object();
    var dateAttr:Date = new Date();
    grAttributes.creationDate = dateAttr;
    var numberAttr:Number = 777;
    grAttributes.n = numberAttr;
    var boolAttr:Boolean = true;
    grAttributes.b = boolAttr;
    var stringAttr:String = "Text";
    grAttributes.s = stringAttr;
    var gr:Graphic = new Graphic(grGeometry, sms, grAttributes);
    gr.toolTip = mx.utils.StringUtil.substitute("{0}\n{1}\n{2}\n{3}",
     gr.attributes.creationDate,
     gr.attributes.n,
     gr.attributes.b,
     gr.attributes.s);
    var grId:String = myGraphicsLayer.add(gr);
    trace(StringUtil.substitute("Graphic with id: {0} added.", grId));
    * Listen export button click handler
   protected function btnExportClick(event:MouseEvent):void
    var arrGraphics:ArrayCollection = myGraphicsLayer.graphicProvider as ArrayCollection;
    if (arrGraphics != null && arrGraphics.length > 0) {
     var fsToExport:FeatureSet = new FeatureSet(arrGraphics.toArray());
     fsToExport.geometryType = Geometry.MAPPOINT;
     if (fsToExport != null) {
      jsonFeatureSet = fsToExport.toJSON();
      trace(jsonFeatureSet);
    * Listen import button click handler
   protected function btnImportClick(event:MouseEvent):void
    if (jsonFeatureSet != null && jsonFeatureSet.length > 0) {
     var fsImported:FeatureSet = FeatureSet.fromJSON(jsonFeatureSet);
     if (fsImported != null) {
      var arrImported:Array = fsImported.features as Array;
      myGraphicsLayer.graphicProvider = arrImported;
    * Listen clear all button click handler
   protected function btnClearClick(event:MouseEvent):void
    myGraphicsLayer.clear();
 </fx:Script>
 <fx:Declarations>
  <!-- Symbol for all point shapes -->
  <esri:SimpleMarkerSymbol id="sms"
         color="0x00FF00"
         size="12"
         style="{SimpleMarkerSymbol.STYLE_DIAMOND}"/>
 </fx:Declarations>
 <esri:Map id="myMap"
     mapMouseDown="myMap_mapMouseDownHandler(event)"
     level="3"
     wrapAround180="true">
  <esri:ArcGISTiledMapServiceLayer url="http://server.arcgisonline.com/ArcGIS/rest/services/World_Imagery/MapServer"/>
  <esri:GraphicsLayer id="myGraphicsLayer" symbol="{sms}"/>
 </esri:Map>
 <s:Button id="btnExport" label="Export to JSON string" click="btnExportClick(event)"/>
 <s:Button id="btnClearAll" label="Clear all graphics" click="btnClearClick(event)"/>
 <s:Button id="btnImport" label="Import from JSON string" click="btnImportClick(event)"/>
</s:Application>
In this sample:
1 - Add graphics clicking on Map
2 - Click export to JSON button
3 - Click clear graphics button
4 - Click import fromJSON button
Symbols 😞
The 1 of the ways, to hold information about symbols = save it in one of the attributes in your graphic object. Parse this attribute when "FeatureSet.fromJSON" complete (create own classes, methods). Create symbol based on parsed data on fly.
Good luck.
PaulHastings1
if fidelity is important maybe ByteArray?
in the app init, register the ESRI classes you're using, eg:
registerClassAlias("com.esri.ags.Graphic", Graphic);
registerClassAlias("com.esri.ags.SpatialReference", SpatialReference);
registerClassAlias("com.esri.ags.geometry.MapPoint", MapPoint);
registerClassAlias("com.esri.ags.geometry.Extent", Extent);
registerClassAlias("com.esri.ags.symbols.SimpleFillSymbol",SimpleFillSymbol);
then to serialize, for example:
protected function addBM(event:MouseEvent):void {
var thisBookmark:Object={};
var bookmark:ByteArray = new ByteArray();
thisBookmark.extent=theMap.extent;
        // gets array of redline graphics in current map extent
thisBookmark.redlines=redlineInExtent();
bookmark.writeObject(thisBookmark);
        // send back to coldfusion for storage
psService.addBM(userID,bookmarksWindow.bmName.text,
          bookmarksWindow.shareBM.selected,new Date().getTime(),bookmarkl);
ByteArray readObject() will deserialize this back to the original data, symbolization & all.
