Enforcing disclaimer acceptance
2549
10
08-22-2010 10:27 PM
JamesOBrien
Hello all,
I'm creating a Flex application and would like to place a disclaimer at the front of it.
I have developed a custom widget which opens when the applicaiton starts.
The problem is that the map is that the map can still be navigated without clicking the 'accept' button on the widget.
I noticed the Map.mapNavigationEnabled property but cannot figure out how to use it.
Has anyone tried this before?
MLowry
Occasional Contributor II
SFV 1.3 or 2.0? Or custom made?
JamesOBrien
I'm extending the latest flex viewer so version 2.0...
JamesOBrien
Thanks Bjorn,
I think you are correct, I will try to use it.
NasifAlshaier
Hi Bjorn
from where you call the splash widget..
I tried to call it from the config.xml and it did not work.
ZahidChaudhry
Occasional Contributor III
What about the Splash Widget? Is that what you are looking for?
http://help.arcgis.com/en/webapps/flexviewer/live/index.html?config=../samples/config-splash.xml
http://help.arcgis.com/en/webapps/flexviewer/help/index.html#widgets/splash_widget.htm
Bjorn,
How can i control the size  (width and Height) of the htmlpopup, when i have lot of text?
and Why I can not use Firefox to post on this forum? (thats one of the reason i use flex and not JS)..
BjornSvensson
In the beta this is not configurable.  We're planning to improve this for version 2.1 of the ArcGIS Viewer for Flex.
I use Firefox 3 without any problems on this forum.  If it doesn't work for you, please report it at http://forums.arcgis.com/forums/81-Resource-Center-Site-Feedback
NadeemShaukat
New Contributor II
Bjorn,
I could show the splash window in the start of the Flexviewer loading with edits in the xml file with my own contentents, but later clicking on the "About" text on the right of the title bar still brings the ESRI's splash window. How and where I make changes to associate my own flash window with "About"?
I do not see any reference in the Config.xml or widget's xml files. I will appreciate your help in this regard.
NadeemShaukat
New Contributor II
Bjorn,
Bjorn,
Never mind. I have found out that this change has to be made in HeaderControler Widget.
