FeatureLayer click offset
343
01-25-2013 03:54 AM
ab1
Occasional Contributor II
I'd like to set an offset for the clicks performed on featureLayers that I have on a map. For example, I want clicks performed 5 meters away from features to be considered as clicks on the features.
Is there any option to activate this offset behaviour?
Regards.
KenBuja
Is this using an IdentifyTask? If so, you can use the IdentifyParameters.tolerance parameter. However, this is the distance in screen pixels from the specified geometry within which the identify should be performed.            You would have to determine the conversion from screen distance to ground distance at the different map scales.
ab1
I'm not using indentify.
I'm using infoWindowRenderer for the featureLayer in question.
