FeatureLayer with Labels
4081
5
04-20-2011 07:20 AM
AndrewHaigh
I'm needing to label features in a FeatureLayer and I want to avoid having a seperate DynamicMapServiceLayer which contains the labels.
One approach I have considered is to extend the FeatureLayer to create a LabelledFeatureLayer class and alter the behaviour of the refresh (?) method.
Has anyone tried something similar to this or does anyone have any better suggestions?
Andrew
by Anonymous User
Not applicable
Andrew
You could create a graphics layer to display the text/ labels as a result of a query against the feature layer. This way you could let the user choose the label field, or make a configurable.
IvanBespalov
com.esri.ags.layers.FeatureLayer extending com.esri.ags.layers.GraphicsLayer
Use com.esri.ags.symbols.CompositeSymbol or com.esri.ags.symbols.TextSymbol to draw label.
Sample is here.
deleted-user-NnRwwd8ols89
Hi, is it possible to label the feature layer (in the mxml) without performing a query?!
thanks!
Ben
...and how would you do the query for a mobile project?! when i import mx.controls.Alert; it says the import Alert could not be found
i'm trying to implement this sample:
http://help.arcgis.com/en/webapi/flex/samples/index.html#/Query_result_on_Map/01nq0000003q000000/
thanks
Ben
IvanBespalov
1 -
Try it : www.adobe.com...
2 -
I think: Yes. I have not found any query maker/caller in this sample.
