I have this code and idk why i cannot get the "zoom" value for the query.
function onResult(featureSet:FeatureSet, token:Object = null):void { try{ var mapPoint:MapPoint = featureSet.features[0].geometry as MapPoint; var convert:ConvertCoords = new ConvertCoords; convert.ToGeographic(mapPoint.x,mapPoint.y); lat = convert.Y_lat; long =convert.X_lon; map.zoomTo(featureSet.features[0].geometry); //Alert.show("punto: " + mapPoint.x.toString() + " " +mapPoint.y.toString()+ " "+ "lat: " + convert.Y_lat.toString()+ " "+convert.X_lon.toString() ); map.level = 16; zoom = featureSet.features[0].attributes["zoom"]; Alert.show(zoom.toString()); }catch(err:Error){ Alert.show("no"); } } function onFault(info:Object, token:Object = null):void { Alert.show("not found"); }
Mensaje editado por: Evelyn Hernandez
i found my problem. I was using another layer and it doesnt have the "zoom" field
Thanks robert
Evelyn,
Your zoom attribute is all upper case in your service so code needs to be as well
zoom = featureSet.features[0].attributes["ZOOM"];
i receive a NaN, what can be the issue?
Evelyn,
What do you receive when you do this on one of the 3 records that does not have a null as its value in your data?
I receive a NaN value. I know that i have some null values , but "PLACILLA" has a zoom value.
I dont know why i cannot get it.
Thanks robert
