Flex Mobile: Switching Between Edit and Non Edit Modes
460
07-26-2013 07:38 AM
MattSheehan
Occasional Contributor III
We have an issue when switching between edit and non edit modes in Flex Mobile. We would like the same seamless functionality we see using the ArcGIS Viewer for Flex:
http://help.arcgis.com/en/webapps/flexviewer/live/index.html?config=apps/config-edit.xml
We are seeing problems with the attribute inspector when we switch into edit mode, as shown in the video below:
http://webmapsolutions.com/demos/attinspectorIssue/attinspectorIssue.html
Wondered if you might be able to shed any light on what might be causing these issues.
Thanks
--Matt
SarthakDatt
Hi Matt,
Looks like when you switch to the edit mode, it still shows the pop-up window. You can set this property https://developers.arcgis.com/en/flex/api-reference/com/esri/ags/Map.html#infoWindowRenderersEnabled to false for the edit mode and toggle it when switching between the modes.
Hope that helps.
MattSheehan
Thanks for the feedback Sarthak. Looks good just one thing left - see the video below -  with the switch back to non edit mode:
http://www.webmapsolutions.com/demos/AttributeInspIssue2/AttributeInspIssue2.html
using this code:
   //Deactivate the editor
   else
    Model.instance.map.infoWindowRenderersEnabled = true;
    //Model.instance.map.infoWindow.hide();
    ModelEdit.instance.editor.templatePicker.clearSelection();
    ModelEdit.instance.editor.featureLayers = null;
    ModelEdit.instance.editor.map = null;
    ModelEdit.instance.editor.drawTool.deactivate();
    ModelEdit.instance.editor.editTool.deactivate();
Thanks again
--Matt
MattSheehan
Found the problem. Thanks again for the help.
