Fx script block help!!
900
6
02-28-2012 10:11 PM
AnN
I am so new, trying to learn the basics of flex!!
I am not sure how the <fx:script> blocks work when there are more than one?! In my case, the script block within a control has no knowledge of the anything else outside of it!!!
For example, the codes below... Please look toward the end at function "protected function pubMapThumb_clickHandler(event:MouseEvent):void".
Within this function, I could not access anything "outside", like the "pubmapList" or any functions in the main <fx:script> block.
Can someone explain that to me, and how would I achieve in doing that? (access "outside" controls).
Thanks so much!!!
[INDENT]
<?xml version="1.0" encoding="utf-8"?>
<s:Group xmlns:fx="http://ns.adobe.com/mxml/2009"
   xmlns:s="library://ns.adobe.com/flex/spark"
   xmlns:mx="library://ns.adobe.com/flex/mx"
   width="1072" height="800" x="0" y="150"
   horizontalCenter="0" verticalCenter="0">
<fx:Declarations>
  <!-- Place non-visual elements (e.g., services, value objects) here -->
</fx:Declarations>
<fx:Script>
  <![CDATA[
   import mx.collections.*;
   [Bindable] public var imgArray:Array = new Array();
   public function createDataProvider():ArrayList
    //var imgArray:Array = new Array();
    for(var i:int=0; i<9; i++)
     imgArray = PathToMyImage();
    return new ArrayList(imgArray);
   private function PathToMyImage():String
    return "http://arcgisonline.com/sharing/content/items/0bb40265b64a4b29ac3bccb774413357/info/thumbnail/global_wetlands.jpg";
</fx:Script>
<mx:Text id="PubMapTitle" text="FEATURED MAPS" fontSize="36" y="45" horizontalCenter="0"/>
<s:List id="pubmapList"
   dragEnabled="false" dropEnabled="false" dragMoveEnabled="false"
   dataProvider="{createDataProvider()}"
   y="110" horizontalCenter="0">
  <s:layout>
   <s:TileLayout id="pubmapListTiles"
        verticalGap="10" horizontalGap="10" horizontalAlign="center" verticalAlign="middle" />
  </s:layout>
  <s:itemRenderer>
   <fx:Component>
    <s:DataRenderer>
     <fx:Script>
      <![CDATA[
       import flash.net.getClassByAlias;
       import mx.controls.Alert;
       import mx.core.UIComponent;
       public var uicomp:UIComponent;
       protected function image1_mouseOverHandler(event:MouseEvent):void
        // TODO Auto-generated method stub
        //Alert.show("Map Info: " + "\n", "Map Details");
        //rollOverTextArea.visible = true;
        //rollOverTextArea.text = "Map Info";
        //rollOverTextArea.x = pubMapThumb.width.valueOf() + 10;
        pubMapThumb.toolTip = "Our Far South - Beyond Stewart Island (ArcGIS Viewer for Public)Live ArcGIS.com Map of the \"Our Far South\" Expedition to Antarctica";
       protected function image1_mouseOutHandler(event:MouseEvent):void
        //rollOverTextArea.visible = false;
        //rollOverTextArea.text = "";
        //removeElement(uicomp);
        uicomp = new UIComponent();
        addElement(uicomp);
        var mapmodule:MapModule = new MapModule();
        mapmodule.setMapServer("http://services.arcgisonline.com/ArcGIS/rest/services/Canvas/World_Light_Gray_Base/MapServer");
        mapmodule.width = Capabilities.screenResolutionX;
        mapmodule.height = Capabilities.screenResolutionY * .80 - 160;
        uicomp.addChild(mapmodule);
     </fx:Script>
     <s:BorderContainer includeInLayout="true" id="imgBorderContainer" borderWeight="3" borderStyle="solid">
      <s:Image id="pubMapThumb" source="{data}" height="200" width="300" mouseOver="image1_mouseOverHandler(event)" mouseOut="image1_mouseOutHandler(event)" click="pubMapThumb_clickHandler(event)"/>
     </s:BorderContainer>
    </s:DataRenderer>
   </fx:Component>
  </s:itemRenderer>
</s:List>
</s:Group>
[/INDENT]
JHayes
As far as I know, you should only have one script block and all you methods in it.  I've never seen Flex code with more that 1.
Joe
KenBuja
Joe
As shown in Dasa's link, it is possible to have more than one script block. A better question would be why it's advantageous to have more than one block.
JHayes
OK.  Why is it advantageous to have more than one script block?
RobertScheitlin__GISP
Well as long as we are just chatting here...
The obvious reason more than one script block would be advantageous is when, like the original posters situation you are doing inline itemRenderers and inline components and need to do some AS3 in the component.
JHayes
My bad guys - I didn't take the time to fully understand the question.  Point taken.
