How to Display Attachments (ArcGIS Viewer for Flex)?
5407
35
02-02-2011 04:38 AM
RamonLeal_Pessoa
New Contributor II
How to display attachment on the ArcGIS Viewer for Flex?
I would like to display jpeg images attachments of "OperationalLayers" with "SimpleInfoWindowWidget" or "InfoPopupWidget"...
Is this possible?
How to do?
Thanks!
ChrisBrannin
@rscheitlin
I do have a question about how the widget decides on how large the image within the info bubble will be. It appears to be in relation to how long the text string is but I am not sure. Is there there a way to standardize the way images are displayed?
RobertScheitlin__GISP
Chris,
   If you look in the AttRelateInfoWinWidget.mxml line 595 is where the image element begins and the maxWidth is set there you can hard code a value if you want to standardize it.
ChrisBrannin
But then does the whole project need to be re-compiled? I am also assuming that because it is set as a percent I can also set it as a pixel value? (sorry if these are dumb questions)
Chris,
   Yep,  you will have to recompile and yep, you can use pixel values (i.e. 400)
ChrisBrannin
I figured as much, thanks again for the help!
LizDaRos
Would this be possible with the Sample Flex Viewer 1.3? ...Showing the attachments using either the identify widget or the search widget?
Thanks~
