how to use asyncronous submitJob and get back job status on server?
758
06-27-2013 07:49 AM
eddiequinlan
Ok, I must be missing something simple......
I have an asyncronous job to create printable maps on the server.  Currently this is accomplished by
MapPrintTask.submitJob(printingparams);
However, I would like to receive the status of the jobs as they are processing.  Therefore, I am trying to use the submitJob task as briefly explained in the esri help.  submitJob(printingparams, 'some responder', 'some status responder')
As in my case I'm doing it as such:  submitJob(printingparams, myResponder, myStatus);
function myResponder():void
do something
function myStatus():void
do something
I can't get the two responders to work properly and get the following error.........
Description Resource Path Location Type
1067: Implicit coercion of a value of type Function to an unrelated type mx.rpc:IResponder.
I'm not sure how the responders work to invoke the function/tasks?
thanx,
Eddie
PaulHastings1
signature for submitJob says those two functions need to use "IResponder" so maybe something like:
printingparams,
new AsyncResponder(myResponder,myResponderFaultHandler),
new AsyncResponder(myStatus,myStatusFaultHandler)
private function myStatus(event:JobInfo,token:Object=null): void {
// do stuff based on event.jobStatus
PaulHastings1
printingparams,
eddiequinlan
Hi Paul,
Thanx for the help.... that did the trick.  I new it was looking for a responder, but I wasn't sure how to set the responder up.
Sincerely,
Eddie
