Mobile App Legend
1609
03-12-2012 12:21 PM
DanielSmith
i'm working on building a simple mobile application using the Esri Flex API and Flash builder 4.5... I am using a tab navigation set up (home, map and overlays)... within my map tab i have a tool bar at the top, one of the tools is used to view the legend (as a different state). When i launch the application i do not get any compile errors but as soon as the app launches i receive this error:
VerifyError: Error #1014: Class mx.controls::Text could not be found.
    at flash.display::MovieClip/nextFrame()
    at mx.managers::SystemManager/deferredNextFrame()
    at mx.managers::SystemManager/preloader_preloaderDocFrameReadyHandler()
    at flash.events::EventDispatcher/dispatchEventFunction()
    at flash.events::EventDispatcher/dispatchEvent()
    at mx.preloaders::Preloader/timerHandler()
    at flash.utils::Timer/_timerDispatch()
    at flash.utils::Timer/tick()
If i dismiss or continue the map and overlays do not draw (though the scale bar and logo do) and the legend only includes text...see images...
[ATTACH=CONFIG]12606[/ATTACH] [ATTACH=CONFIG]12607[/ATTACH] [ATTACH=CONFIG]12608[/ATTACH]
here is my legend code (import components... state change function....legend component):
     import com.esri.ags.skins.LegendSkin;
     import com.esri.ags.components.Legend;
           private function legendClick (event:MouseEvent):void
                switch(currentState)
                    case"State1":
                        currentState = 'ShowLegend';
                        break;
                    case"ShowLegend":
                        currentState = 'State1';
                        break;
    <s:VGroup width="100%" height="100%" includeIn="ShowLegend">
        <esri:Legend id="legend" includeIn="ShowLegend" layers="{[ dynamicService ]}" map="{myMap}" respectCurrentMapScale="true" height="100%" width="100%" />
    </s:VGroup>
should i use a pop up alert instead maybe? do i really even need the aditional container?
any helps is greatly appreciated..
by Anonymous User
Not applicable
Original User: TOVernon
I quickly created a legend using a border container set visible to false, create a function to set visible to true, tied that to a button, and it worked fine.
