My attributes are in the correct order in Arc but when I run my Flex application the attributes in the Inspector are all out of order. Also, how do you make the attributes show with their alias instead of the actual names. Thanks.
After upgrading to 3.0, the default order should be "fields", which should be the order of your outFields on your FeatureLayers or the layers published field order if you don't set the outFields or if they're set to just "*". Is that what you're seeing now?
You don't need a function since the "formFieldsOrder" property can only have three possible values.
I'm using version 2.5, and no, I have not tried this AttributeInspector.formFieldsOrder method. I just looked it up and am quite confused as to where and how I would implement this. Could you clarify? Thanks.
