Sherly, You do not get a graphic back from a project operation, you get an array of geometries.<?xml version="1.0" encoding="utf-8"?> <s:View xmlns:fx="http://ns.adobe.com/mxml/2009" xmlns:s="library://ns.adobe.com/flex/spark" title="Map" xmlns:esri="http://www.esri.com/2008/ags" xmlns:mx="library://ns.adobe.com/flex/mx" creationComplete="init()"> <fxeclarations> <s:HTTPService id="srv" url="xml/properties.xml" result="resultHandler(event)"/> <esri:GeometryService id="geometryService" url="http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer"/> </fxeclarations> <fx:Script> <=!=[=C=D=A=T=A=[ import com.esri.ags.Graphic; import com.esri.ags.SpatialReference; import com.esri.ags.events.GeometryServiceEvent; import com.esri.ags.geometry.Geometry; import com.esri.ags.geometry.MapPoint; import com.esri.ags.layers.GraphicsLayer; import mx.collections.ArrayCollection; import mx.rpc.events.ResultEvent; [Bindable] private var watdata:ArrayCollection; private var myObject:Object; private var latlong:Number; private var stName:String; private var point:Geometry; private var attrib:String; private var graphicsLayer:GraphicsLayer; private function init():void{ graphicsLayer = new GraphicsLayer; graphicsLayer.name = "pointgra"; map.addLayer(graphicsLayer); srv.send(); } private function resultHandler(event:ResultEvent):void{ watdata = event.result.properties.data; var gArr:Array = []; var graphics:Array = []; for each (myObject in data) { latlong = Number(myObject.point.toString()); stName = myObject.name.toString(); attrib = {sName:stName}; point = new MapPoint(latlong, new SpatialReference(102100)); var uGraphic:Graphic = new Graphic (point, attrib); gArr.push(point); graphics.push(uGraphic); } var outSR:SpatialReference = new SpatialReference(3857); geometryService.project(gArr, outSR, new AsyncResponder(projectCompleteHandler, null, graphics)); } protected function projectCompleteHandler(result:Object, token:Object):void { var pRslts:Array = result as Array; for (var pg:int = 0; pg < pRslts.length; pg++){ var pGeom:Geometry = pRslts[pg]; token[pg].geometry = pGeom; } graphicsLayer.graphicProvider = token; graphicsLayer.addEventListener(TouchEvent.TOUCH_OVER, tover); graphicsLayer.addEventListener(TouchEvent.TOUCH_OUT, tout); } private function tover(event:TouchEvent):void{ var graphic:Graphic = event.target as Graphic; graphic.toolTip = graphic.attributes.sName.toString(); } private function tout(event:TouchEvent):void{ var graphic:Graphic = event.target as Graphic; } ]=]=> </fx:Script> <s:navigationContent> <s:Button width="75" height="50" click="navigator.popView()" icon="assets/back.png"/> </s:navigationContent> <esri:Map id="map" width="100%" height="100%" logoVisible="true" navigationClass="{null}" zoomSliderVisible="true" openHandCursorVisible="false" scale="50000000"> <esri:ArcGISTiledMapServiceLayer url="http://services.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer"/> <esri:extent> <esri:Extent xmin="-467799" ymin="5253018" xmax="2171419" ymax="6627661"/> </esri:extent> </esri:Map> </s:View>
Don't forget to click the Mark as answer check and to click the top arrow (promote) as shown below:
