Hello Xinato,You need the class ESRI.ArcGIS.SOESupport.Conversion. I use this code in Desktop, but probably it works for you. Try something like this:
using ESRI.ArcGIS.Geometry;
using ESRI.ArcGIS.SOESupport;
public class JSonBiz
private const string JSON_GEOMETRY = "geometry";
private const string JSON_SPATIAL_REFERENCE = "spatialReference";
private const string JSON_RINGS = "rings";
private const string JSON_PATHS = "paths";
private const string JSON_POINTS = "points";
private const string JSON_Z = "z";
public static IGeometry ToGeometry(string strJson)
IGeometry pGeometry = null;
JsonObject pJsonObject = null;
JsonObject pJsonObjectGeometria = null;
JsonObject pJsonObjectSpatialReference = null;
ISpatialReference pSpatialReference = null;
try {
//Parse
pJsonObject = new JsonObject(strJson);
//Get geometry
if (pJsonObject.TryGetJsonObject(JSON_GEOMETRY, pJsonObjectGeometria)) {
pGeometry = getGeometry(pJsonObjectGeometria);
//Set spatial reference
if ((pGeometry != null) && pJsonObject.TryGetJsonObject(JSON_SPATIAL_REFERENCE, pJsonObjectSpatialReference)) {
pSpatialReference = Conversion.ToSpatialReference(pJsonObjectSpatialReference.ToJson());
if ((pSpatialReference != null)) {
pGeometry.SpatialReference = pSpatialReference;
} catch (Exception ex) {
pGeometry = null;
//Maybe show your own error
return pGeometry;
private static IGeometry getGeometry(JsonObject jsonObjectGeometry)
IPoint pPoint = null;
IZAware pZAware = default(IZAware);
double dblZ = 0;
object[] objArray = null;
//Test all
if (jsonObjectGeometry.TryGetArray(JSON_RINGS, objArray)) {
//Polygon
pGeometry = Conversion.ToGeometry(jsonObjectGeometry, esriGeometryType.esriGeometryPolygon);
} else if (jsonObjectGeometry.TryGetArray(JSON_PATHS, objArray)) {
//Polyline
pGeometry = Conversion.ToGeometry(jsonObjectGeometry, esriGeometryType.esriGeometryPolyline);
} else if (jsonObjectGeometry.TryGetArray(JSON_POINTS, objArray)) {
//Multipoint
pGeometry = Conversion.ToGeometry(jsonObjectGeometry, esriGeometryType.esriGeometryMultipoint);
} else {
//Point
try {
pPoint = Conversion.ToGeometry(jsonObjectGeometry, esriGeometryType.esriGeometryPoint);
//z value
if (jsonObjectGeometry.Exists(JSON_Z) && jsonObjectGeometry.TryGetAsDouble(JSON_Z, dblZ)) {
//Test value
if (double.IsNaN(dblZ)) {
dblZ = 0;
//Set value
pZAware = pPoint;
pZAware.ZAware = true;
pPoint.Z = dblZ;
pGeometry = pPoint;
pGeometry = null;
//Envelope
if (pGeometry == null) {
try {
pGeometry = Conversion.ToGeometry(jsonObjectGeometry, esriGeometryType.esriGeometryEnvelope);
} catch (Exception ex2) {
pGeometry = null;
//Simplify (Maybe you don't need it)
if ((pGeometry != null)) {
ITopologicalOperator pTopologicalOperator = pGeometry;
pTopologicalOperator.Simplify();
return pGeometry;
public static string ToJSon(ref IGeometry pGeometry)
string strJson = null;
strJson = System.Text.Encoding.ASCII.GetString(ESRI.ArcGIS.SOESupport.Conversion.ToJson(pGeometry));
return strJson;
Hope it helps.RegardsEsther
