replace powered by ESRI
5138
70
07-22-2010 02:01 AM
NatashaManzuiga
Hi all I perfectly replaced ESRI logo with this script:
http://forums.esri.com/thread.asp?t=287497&f=2421&c=158#912795
Now how can I replace link to esri.com/flex?
Naty
RobertScheitlin__GISP
Naty,
   Try this
private function changeESRILogo(map:Map):void {
    for(var i:int = 0 ; i < map.numChildren ; i++){
     var component:UIComponent = map.getChildAt(i) as UIComponent;
     if(component.className == "StaticLayer"){
      for(var j:int = 0 ; j < component.numChildren ; j++){
       var stComponent:UIComponent = component.getChildAt(j) as UIComponent;
       if(stComponent.className == "Image"){
        var img:Image = stComponent as Image;
        if (img.source.toString().indexOf("logo") > 0){
         img.source = myLogo;
         img.addEventListener(MouseEvent.MOUSE_DOWN ,gotoMyURL,false,1000);
         return;
private function gotoMyURL(evt:Event):void
    var myURL:URLRequest = new URLRequest("http://www.google.com/");
    navigateToURL(myURL);
    evt.stopPropagation();
NatashaManzuiga
Naty,
   Try this
         return;
Great Robert!!
I just have the last question for u 🙂 How can I do this?
Thanks Robert
http://forums.arcgis.com/threads/8310-Activate-Graphical-Search-Select-by-Point-%28SearchWidget%29-f...
deleted-user-rQoEFM5qzbHE
New Contributor II
Where would I put these two functions?
Jeremy,
   Depends on what your app is... Are you talking a custom flex api app, Sample Flex Viewer 1.x or FlexViewer 2.0?
New Contributor II
Sorry, I am attempting to modify the Flex Viewer 2.0 API.
Jeremy,
   In that case this code goes in the MapManager.mxml.
New Contributor II
Thanks for the response. And, since I have your attention is this where I would put the code related to clustering? I tried to put that in the ViewerContainer.mxml (I am pretty sure this was wrong, but didn't know where to put it) and it kind of works, but it the layers come up behind the existing services found in the config.xml.
Jeremy,
   Not sure which clustering code you are referencing but as clustering is a layer than yes it should go in the MapManager.
New Contributor II
It is the code found in the samples section for ArcGIS API for flex. I get an error for the section inside of the Declaration tag. The error says that the 'prefix "text" for element "text:TextFormat" is not bound'. Thanks again for all your help.
