Ok, this one I solved myself.It was as easy as to type in "requestip" under clientid.public function RequestToken(username:String, password:String):void {
var http:HTTPService = new HTTPService();
http.addEventListener( ResultEvent.RESULT, tokenResultHandler );
http.addEventListener( FaultEvent.FAULT, faultHandler );
// parameters for the request
var param:Object = {
"request" : "gettoken",
"username": username,
"password": password,
"clientid" : "requestip",
"expiration" : expir
// prepare the httpService object for send the request
http.url = "https://yourservername/arcgis/tokens?tokens"; // fake parameter ?tokens for start the process of token generation
http.method = "POST"; // set POST method for not have problem in cache and logs
http.resultFormat = "text";
http.request = param; // set parameters for the request
http.send();
function faultHandler(event:FaultEvent):void {
navigator.pushView(loginView);
Alert.show(event.fault.toString());
function tokenResultHandler(event:ResultEvent):void {
var theToken:String = StringUtil.trim(event.result.toString()); // trim the generated token for surprise...
loadProtectedMaps(theToken);
