var Att = {Location: "Location"} function hideDiv() { if (Att = '') {document.getElementById("testdiv").style.visibility= 'hidden';} }else{ document.getElementById("testdiv").style.visibility='visible';} }; }
<div id="testdiv"> <a href="{'http://000.000.000.000/flexviewers/app/'+Att.Location.toString()}" target=_blank>Location</a> </div>
var Att = {Location: "Location"} function hideDiv() { if (Att.Location.toString() == ''){ //if the Att object's location is cast to a string and is empty document.getElementById("testdiv").style.visibility= 'hidden';} //hide the div }else{ //if it is not an empty string document.getElementById("testdiv").style.visibility='visible';}//show the div }; }
var Att = {Location: "Location"} function hideDiv() { if (Att.Location.toString() == ''){ //if the Att object's location is cast to a string and is empty document.getElementById("testdiv").style.visibility= 'hidden'; //hide the div }else{ //if it is not an empty string document.getElementById("testdiv").style.visibility='visible';//show the div }; };
Att.eLocation.toString()
<?xml version="1.0" ?> <configuration> <title>{REVIEW_DESC}</title> <script type="text/javascript"> var Att = {Locations: "Locations"} function hideDiv() { if (Att.Locations.toString() == ''){ //if the Att object's location is cast to a string and is empty document.getElementById("testdiv").style.visibility= 'hidden'; }else{ //if it is not an empty string //if it is not an empty string document.getElementById("testdiv").style.visibility='visible';}; } </script> <description> <![CDATA[ <div id="testdiv"> <a href="{'http://146.129.110.197/flexviewers/app/Locations/'+Att.Locations.toString()}" target=_blank>Location</a> </div> Location: {Locations} // HAS DATA I want to use in the javascript Location2: {Att.Locations.toString()} // NO DATA coming from javascript </configuration>
