ConnectionError - Overcoming proxy to access ArcGIS Online via the ArcGIS API for Python
273
4 weeks ago
Clubdebambos
Hello all,
I remote into a machine and there is a proxy in use. I cannot access AGOL via the ArcGIS API for Python.
I try:
from arcgis.gis import GIS
agol = GIS("home")
or
agol = GIS(url="", username="", password="")
but I consistently get the following error.
ConnectionError: A connection error has occurred: HTTPSConnectionPool(host='xxx.maps.arcgis.com', port=443): Max retries exceeded with url: /sharing/rest/portals/self (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x000001B61ED92730>: Failed to establish a new connection: [WinError 10060] A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond'))
Note, I can access just fine without the proxy from my laptop, but I must complete work on the remote machine that has the proxy. So accessing AGOL is not the issue, it is overcoming the proxy.
 Any ideas?
Cheers,
~ learn.finaldraftmapping.com
EarlMedina
Hey, have you tried using the proxy parameter? I've heard mixed reviews, but hopefully your proxy is more forgiving:
# Usage Exmaple 9: Using a Proxy
proxy = {
    'http': 'http://10.10.1.10:3128',
    'https': 'http://10.10.1.10:1080',
gis = GIS(proxy=proxy)
EarlMedina
proxy = {
Clubdebambos
Hi @EarlMedina
Excellent, this approach worked. Here's what I was given, this failed to connect.
proxy = {
    "http" : "http://**.***.*.**:XXXX"
 This worked when I added the same information for the https key.
proxy = {
    "http" : "http://**.***.*.**:XXXX",
    "https" : "http://**.***.*.**:XXXX"
agol = GIS("home", proxy=proxy)
Thanks you!
jcarlson
I recently had to downgrade the urllib3 package to get my ArcGIS Python API to work correctly. Did you update your Python env recently?
- Josh Carlson
Kendall County GIS
Clubdebambos
Hi @jcarlson
It was not a recent upgrade, but thank you for your response. This is great to know and I will keep an eye out for this when upgrades happen. Earls solution above worked after testing dictionary configs.
