Create feature class with "objectid" lowercase, Python?
1211
6
04-17-2017 11:01 PM
MarkMindlin
We have an old code that works with a feature class with field "objectid" lowercase.
I just wondering how can one create a feature class with lowercase "objectid"?
It is possible with Python? or C#?
Any help will be greatly appreciated.
MarkMindlin
We did it with
Export->XML Workspace Document
Manually change to lowercase in the XML
Import ->XML Workspace Document
Load
MarkMindlin
Can we use an XML schema for that? How?
DanPatterson_Retired
why not modify the code to convert the case to lower when the objected is needed.  If you attempt to make it useable in the other program, it won't be useable in Arc*.  Alternately, export to a format that both programs can agree upon
MarkMindlin
Thank you, Dan.
I see what you mean. I would definitely change the code. But..
The code is unreachable for me to change.
MarkMindlin
If we have old "rid" field of type "ObjectID"
could we AlterField to "objectid"?
MarkMindlin
It actually works.
I am not sure if the type of the field could be set to "ObjectID".
MarkMindlin
We did it with
Load
