Create view layer in arcgis python api and make certain fields visiblity to be off and editable properties should be false
690
07-21-2023 06:10 AM
SriyankarDandapat
I have created a view_layer using below code but i have not get any reference to update the visibility and editability properties for each feature layers. I have use the below code, please refer any process of how i could be able to update the properties.
import arcgis
from arcgis.features import FeatureLayer
from arcgis.features import FeatureLayerCollection
user_name = "UserName"
pass_word = "PassWord"
gis = arcgis.gis.GIS("https://www.arcgis.com", user_name, pass_word)
layer_name = "My_layer"
view_name = "My_view1"
layer_index = 0
view_def = {"viewDefinitionQuery": "Fields in ['ch_name']"}
search_results = gis.content.search(layer_name, item_type="Feature Layer")
proper_index = [index for index, s in enumerate(search_results)
if '"' + layer_name + '"' in str(s)]
found_item = search_results[proper_index[0]]
flc = FeatureLayerCollection.fromitem(found_item)
new_view = flc.manager.create_view(name=view_name)
view_flc = flc
view_layer = view_flc.layers[layer_index]
flc.manager.update_definition(view_def)
The code show error for the following line:
"view_def = {"viewDefinitionQuery": "Fields in ['ch_name']"}"
Please assist me to write the veiw defination correctly to disply only selected fields.
NiharSahoo
By setting the the specific fields visibile and editable properties to be False and then update_defination for the feature collection we can achieve it.
SFM_TravisBott
Did you ever find an answer for this? I was searching for the same thing and came across your post....it just doesn't have much in it.
