Not directly. It is common for ArcGIS API for Python to be installed in a Python environment that also has ArcPy, and ArcPy provides the ability to make direction connections to databases, both regular and geo-enabled. Even if ArcGIS API for Python supported connecting directly to geodatabases, it would likely require or use ArcPy code, so adding that support doesn't add much value.
