I have solved the issue. The GP service output should be of type "File". The user can click a link and the zip file downloads. The Portal arcgisjobs folder is used for the shapefile and the zip file. Code to follow:
# ExportShapefile - Created by Jeff Hanson, HFM
# Purpose: to export selected featues to a usernamed shapefile as a geoprocessing servie
# Note: the output directory is PortalShapeFiles on Hertzgis server, a shared folder
import arcpy, os, json, sys, zipfile, urllib2
### setting variable default values
arcpy.AddMessage("Default scratch GDB is:")
arcpy.AddMessage(arcpy.env.scratchGDB)
arcpy.AddMessage("*******************************")
# Excel table output folder
exportFolder = arcpy.env.scratchGDB
jobsDir = os.path.dirname(os.path.abspath(exportFolder))
arcpy.AddMessage("Export Folder: " + exportFolder)
arcpy.AddMessage("Jobs Dir: " + jobsDir)
### Getting input parameters
arcpy.AddMessage("Collecting input parameters")
# Get the passed field polygon graphics and user specified shapefile name
inFeatset = arcpy.GetParameter(0)
if inFeatset == '#' or not inFeatset:
sys.exit()
shpFileName = arcpy.GetParameterAsText(1)
outputShapeFile = jobsDir + "\\" + shpFileName + ".shp"
if not shpFileName:
sys.exit()
arcpy.AddMessage("Output file is " + outputShapeFile)
### start main proccess
try:
arcpy.AddMessage("Running shapefile export to create " + outputShapeFile)
arcpy.CopyFeatures_management(inFeatset, outputShapeFile)
arcpy.AddMessage("Created shapefile: " + outputShapeFile)
# put the files that make up the shapefile into a zip file
zip = zipfile.ZipFile(jobsDir + "\\" + shpFileName + ".zip", 'w', zipfile.ZIP_DEFLATED)
for file in os.listdir(jobsDir):
if file.startswith(shpFileName):
if not file.endswith(".zip"😞
print(os.path.join(jobsDir, file))
zip.write(os.path.join(jobsDir, file))
zip.close()
arcpy.AddMessage("Zip file created.")
outputFile = jobsDir + "\\" + shpFileName + ".zip"
arcpy.AddMessage("Return file is " + outputFile)
arcpy.SetParameter(2, outputFile)
except:
arcpy.AddMessage("Error exporting and downloading shapefile " + outputShapeFile)
sys.exit()
