Error at Multiprocessing - “Manage Tile Cache” tool in parallel processing
640
06-25-2017 04:30 PM
MarkMindlin
We use the tool "Manage Tile Cache" on the local machine Desktop in ArcMap 10.5, for ArcGIS Server 10.3.
Parameter "area_of_interest" is the feature class created by CacheWorx "Coverage To Feature" Level 19
The help says: "For the fastest tile creation, your CPU should be working near 100% during the tile creation"
Having 16 cores CPU, and using ParallelProcessingFactor 100% or 16
the CPU usage is very low - between 3 to 8 percents
In order to find a workaround I tried to use a script with multiprocessing.
Unfortunately, it has an error at the run time. Please help to make it working.
The script
#run “Manage Tile Cache” tool in parallel processing
import arcpy
import multiprocessing
import os
import glob
import sys
import traceback
from multiprocessing import Process, Queue, Pool, \
    cpu_count, current_process, Manager
arcpy.env.scratchWorkspace = "in_memory"
AAA_Imagery = "D:/gisdata/imagery/public_AAA_Imagery/AAA_Imagery"
Manage_Mode = "RECREATE_ALL_TILES"
Scales__Pixel_Size___Estimated_Disk_Space_ = "564.248588"
Best_WebM = "D:/gisdata/imagery/BestMosaic_2017test.gdb/Best_WebM"
Level_20_coverage = "D:/gisdata/imagery/Levels_coverage.gdb/Level_20_coverage"
def execute_task(bundleAOI):
    try:
        result = arcpy.ManageTileCache_management(AAA_Imagery, Manage_Mode, "", Best_WebM, "ARCGISONLINE_SCHEME", "", Scales__Pixel_Size___Estimated_Disk_Space_, bundleAOI, "", "591657527.591555", "282.124294")
        print(arcpy.GetMessages())
        print "result: " + result
    except Exception, e:
        e.traceback = traceback.format_exc()
        raise
if __name__ == '__main__':
    #get individual bundles, add it to a dictonary
    bundles = {}
    count = 1
    for bundle in arcpy.da.SearchCursor(Level_20_coverage,["*"]):
        bundles[count] = bundle
        count += 1
    # create a process pool and pass dictonary of extent to execute task
    pool = Pool(processes=cpu_count())
    pool.map(execute_task, bundles.items())
    pool.close()
    pool.join()
The error (see the image)
