Is there still no work around for this? I am currently dealing with this.
I am updating an event every couple of minutes. An event, x1, is ingested. It holds x1 for an approximate time. Another event happens. It ingests event 2, x2. It (x2) compares itself to x1, though, to see if it is the same event. It runs into some issues because it uses certain fields to do this. The problem is the fields are now being changed.
This is happening even though there are 2 data frames managing these fields that whole time. The problem begins with the portal altering the field names, for example from AllUpperCase to all_lower_case.
If I figure anything out, I will share.
