I know you can increase the time before a token expires when using the Arcgis REST API in the parameters you pass, but can you do the same using the Arcgis Python API? I know how to access the token using 'gis._con.token' and the time beofre expiry with 'gis._con._expiration', but is there somewhere I can increase the time before expiration to higher than the default 60 minutes via the python API? Or should I simply re-authenticate my credentials using 'GIS(portal, username, password)' after 60 minutes?
