In Arc Pro 2.6, the message ERROR 000210: Cannot create output memory\example is returned after I run my geoprocessing script. The script is using Python 3.6.
I understand that Arc PRO is different from ArcMap in that it is 64-bit and does not block the application while a tool is running. I read, however, that the mulithreaded approach writes on-disk in PRO when using "in_memory\\example " and not to memory as I prefer. Using "memory\example", seemed to be the solution, but then it results in the error mentioned above.
Can you please help me in identifying a way to write to memory as I did in ArcMap with the goal of publishing? Below is a bit of the code that I used. Any help is appreciated.
#Import arcpy modules
from arcpy import MakeQueryLayer_management
from arcpy import CopyFeatures_management
from arcpy import env
#Local Variables
LPRMQ = r"memory\LPRMQ"
#Input/Output
PIDNum = arcpy.GetParameterAsText(0)
arcpy.SetParameterAsText(1, r"memory\LPR")
# Set Geoprocessing environments
arcpy.env.scratchWorkspace = "C:\\Users\\..."
arcpy.env.workspace = "C:\\Users\\..."
arcpy.MakeQueryLayer_management(DB, LPRMQ, "SELECT ...")
arcpy.CopyFeatures_management(LPRMQ, r"memory\LPR", "", "0", "0", "0")
Lynn
