Have you seen this before:
item = gis.content.get('0063eabbf6b94220a6c671b898c454b9')
gis2.content.clone_items([item])
RuntimeError Traceback (most recent call last)<ipython-input-15-000e99e9d2b6> in <module>()----> 1 gis2.content.clone_items([item])C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\gis\__init__.py in clone_items(self, items, folder, item_extent, use_org_basemap, copy_data, search_existing_items, item_mapping, group_mapping) 3119 wgs84_extent = clone._wgs84_envelope(service_extent) 3120 deep_cloner = clone._DeepCloner(self._gis, items, folder, wgs84_extent, service_extent, use_org_basemap, copy_data, search_existing_items, item_mapping, group_mapping)-> 3121 return deep_cloner.clone() 3122 3123 def _bulk_update(self, itemids, properties):C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\_impl\common\_clone.py in clone(self) 523 asyncio.set_event_loop(asyncio.new_event_loop()) 524 loop = asyncio.get_event_loop()--> 525 results = loop.run_until_complete(self._clone(executor)) 526 loop.close() 527 return results C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\asyncio\base_events.py in run_until_complete(self, future) 453 future.add_done_callback(_run_until_complete_cb) 454 try:--> 455 self.run_forever() 456 except: 457 if new_task and future.done() and not future.cancelled():C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\asyncio\base_events.py in run_forever(self) 407 self._check_closed() 408 if self.is_running():--> 409 raise RuntimeError('This event loop is already running') 410 if events._get_running_loop() is not None: 411 raise RuntimeError( RuntimeError: This event loop is already running
Fraser
EDIT: actually looks like an issue with Notebook environment - works fine from an IDE such as Pycharm
See Can't invoke asyncio event_loop after tornado 5.0 update · Issue #3397 · jupyter/notebook · GitHub
