Converting from the geodataframe that has z values to a spatial data frame, I lose the z values.
When I export out a shapefile from the geopandas geodataframe, then load that back into the arcgis spatial data frame, the spatial data frame has z enabled.
So I cannot convert from a geodataframe to a spatial dataframe and keep the z values? I will need to write out to a shapefile, then read it back in to get the z enabled sdf
