I want to publish a CSV to Enterprise Portal. So far, I have been unsuccessful. First, I use the content manager to add the CSV to the Portal. Then I try publishing using the Item ID of that newly added item. The item gets added, as I used a print statement to verify the Item ID. The exception is telling me it already exists? Does it not have to first exist as an item in order to publish?
My CSV is attached. Here's my script followed by the error.
from arcgis import GIS, features
#Connection to ArcGIS Enterprise Portal running 10.8
gisE = GIS(url='', username='', password='', verify_cert=False, trust_env=False)
cm = gisE.content
#Add CSV to ArcGIS Enterprise
item = cm.add(item_properties={
'title' : 'VaccineCurrent2',
'tags' : 'test',
'type' : 'CSV'}, data=csv_file)
item_id = item.id
print(item_id)
#Publish
pitem = item.publish(item_id=item_id, file_type='csv')
4b872c25baf7448f845e7c15912f4c9a ##<---this is the ouput of print statement
File "\\Python Scripts\ArcGISPro\test.py", line 47, in <module>
File "C:\Users\jpilbeam\Miniconda3\envs\env1\lib\site-packages\arcgis\gis\__init__.py", line 10340, in publish
folder, buildInitialCache, item_id=item_id)
File "C:\Users\jpilbeam\Miniconda3\envs\env1\lib\site-packages\arcgis\gis\_impl\_portalpy.py", line 408, in publish_item
resp = self.con.post(path, postdata, files)
File "C:\Users\jpilbeam\Miniconda3\envs\env1\lib\site-packages\arcgis\gis\_impl\_con\_connection.py", line 720, in post
force_bytes=kwargs.pop('force_bytes', False))
File "C:\Users\jpilbeam\Miniconda3\envs\env1\lib\site-packages\arcgis\gis\_impl\_con\_connection.py", line 514, in _handle_response
self._handle_json_error(data['error'], errorcode)
File "C:\Users\jpilbeam\Miniconda3\envs\env1\lib\site-packages\arcgis\gis\_impl\_con\_connection.py", line 536, in _handle_json_error
raise Exception(errormessage)
Exception: Unable to publish item.
Item with Id '4b872c25baf7448f845e7c15912f4c9a already exists.
(Error Code: 400)
EDIT: when I run the analyze() call on the CSV I get JSONDecodeError.
analyze_csv = cm.analyze(item=item, file_type='csv')
File "\\ArcGISPro\test.py", line 41, in <module>
File "C:\Users\jpilbeam\Miniconda3\envs\env1\lib\site-packages\arcgis\gis\__init__.py", line 4381, in analyze
return gis._con.post(path=surl, postdata=params, files=files)
File "C:\Users\jpilbeam\Miniconda3\envs\env1\lib\site-packages\arcgis\gis\_impl\_con\_connection.py", line 504, in _handle_response
data = resp.json()
File "C:\Users\jpilbeam\Miniconda3\envs\env1\lib\site-packages\requests\models.py", line 900, in json
return complexjson.loads(self.text, **kwargs)
File "C:\Users\jpilbeam\Miniconda3\envs\env1\lib\json\__init__.py", line 348, in loads
return _default_decoder.decode(s)
File "C:\Users\jpilbeam\Miniconda3\envs\env1\lib\json\decoder.py", line 337, in decode
obj, end = self.raw_decode(s, idx=_w(s, 0).end())
File "C:\Users\jpilbeam\Miniconda3\envs\env1\lib\json\decoder.py", line 355, in raw_decode
raise JSONDecodeError("Expecting value", s, err.value) from None
json.decoder.JSONDecodeError: Expecting value: line 1 column 1 (char 0)
