Hi Josh,
What is the syntax for setting the input map to create a mobile map package?
For example using the python console in pro mine would be as follows:
arcpy.management.CreateMobileMapPackage("Map Title", r"J:\path\PackageName.mmpk", None, None, "DEFAULT", "SELECT", "Title", "Summary", '<DIV STYLE="text-align:Left;font-size:12pt"><P><SPAN>Sewer Network</SPAN></P></DIV>', "Sewers", None, None, "STANDARD")
The code sample in the help article you provided for a stand alone script is as follows:
arcpy.management.CreateMobileMapPackage( [r"C:\data\Basemap1.mapx", r"C:\data\Map1.mapx"], outputfile, None, r"\\share\layers\AreaOfInterest.lyrx", "DEFAULT", "CLIP", "Title", "Summary", "description", "Tag", "Credits", "Use", "STANDARD", "ENABLE_MAP_EXPIRATION", "DONOT_ALLOW_TO_OPEN", expiration_date, "This map is expired. Contact the map publisher for an updated map.")
but the input is a map file, how do i set the input to be a map within a project? Or do i have to save the map as a map file first?
Any help would be much appreciated.
Thanks
