Version 1.6.0 yet unknow to Anaconda ?
657
6
03-06-2019 03:40 AM
Rolandvan_Zoest
New Contributor III
Version 1.6.0 is not being installed by "conda upgrade arcgis".
It says 1.5.3 is already installed ...
DanPatterson_Retired
Your 'pinned' file C:\<install_directory>\bin\Python\res\pinned
is probably limiting it to versions of 1.5
arcgis 1.5.*
but
https://anaconda.org/esri/ArcGIS
shows conda install -c esri arcgis
Rolandvan_Zoest
New Contributor III
Hello Dan,
INDEED !
It came with ArcGisPro 2.3(.1) ...
Is it safe to change this this line to arcgis 1.. ?
Roland @ GeoDesk
Wageningen University
Netherlands
let us know
Rolandvan_Zoest
New Contributor III
Changing arcgis 1.5.* to arcgis 1.6.* in file “pinned”
made conda upgrading package arcgis to 1.6.0
Use the “pinned” file in the right/active environment !
For me this was in C:\Users\<name>\AppData\Local\ESRI\conda\envs\<name>\conda-meta
I’m glad this worked, because this update solves a serious problem in arcgis.gis
Roland
Just drop the --dry-run when you think it will do no damage
(arcgispro-py3) C:\arc_pro\bin\Python\envs\arcgispro-py3>conda upgrade arcgis -c esri --no-pin --dry-run
Fetching package metadata .............
Solving package specifications: .
Package plan for installation in environment C:\arc_pro\bin\Python\envs\arcgispro-py3:
The following packages will be UPDATED:
    arcgis:   1.5.3-py36h66efe7d_1 esri --> 1.6.0-py36h92ab3c2_1 esri
The following packages will be SUPERSEDED by a higher-priority channel:
    freetype: 2.8-h51f8f2c_1            --> 2.8-vc14_0           esri [vc14]
Rolandvan_Zoest
New Contributor III
This is conda usage at level 3
Thanks Dan !
