Attribute Query Task Question
1664
11
11-01-2010 10:53 AM
ChristineZeller
I'm trying to implement the Attribute Query example from the SDK and I can get it working on my machine "as is" but when I change over to a layer that I'm servering it doesn't work. Also if I change the example to just use a different field like STATE_ABBR instead of STATE_NAME I have the same problem....it breaks!  Am I missing a change?
Christine
JenniferNery
When you say "it breaks", what error message do you see? Have you tried to use Fiddler to see where it possibly fails?
ChristineZeller
Jennifer, thanks for the reply!  Yea it fires when I use the State_Name but like I said if I just switch it to a different field like STATE_ABBR (just two easy changes in the code behind).  It never returns the query and/or zooms to the feature.  Here's the last fiddler.
I've attached a screen shot of my last fiddler result.
It seems like there is some little stupid change I'm missing.  Do I need to change the WHERE?  I not really sure what the where is stating  "query.Where = "1=1";"
Christine
JenniferNery
Oh I see what the problem is now. In this sample http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#AttributeQuery (if you are using this), the query OutFields only include "STATE_NAME".
The service that it's using is http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Census_USA/MapServer/5 and "STATE_ABBR", while it is a valid field, is not included in the OutFields. You can update this line
query.OutFields.AddRange(new string[] { "STATE_NAME", "STATE_ABBR" });
//or simply use * to return all fields -- query.OutFields.Add("*");
ChristineZeller
Jennifer, thanks again for the replies. I am using the sample you pointed to. I was just changing the code like:
// Specify fields to return from initial query
//query.OutFields.AddRange(new string[] { "STATE_ABBR" });
If I try this instead:
I get the same results...no return...just sits there
If I try:
I get the same.
The only other thing I'm changing is
 if ((args.UserState as string) == "initial")
                // Just show on initial load
                QueryComboBox.Items.Add("Select...");
                foreach (Graphic graphic in args.FeatureSet.Features)
                    QueryComboBox.Items.Add(graphic.Attributes["STATE_ABBR"].ToString());
                QueryComboBox.SelectedIndex = 0;
                return;
JenniferNery
Looking at how the Query is formed, it uses Text property which checks against the layer's DisplayField http://help.arcgis.com/en/webapi/silverlight/apiref/ESRI.ArcGIS.Client~ESRI.ArcGIS.Client.Tasks.Quer...
In the given layer, DisplayField is STATE_NAME, therefore the query with STATE_ABBR does not return any results.
I will update Where property instead of Text property in the SelectionChanged event handler.  http://help.arcgis.com/en/webapi/silverlight/apiref/ESRI.ArcGIS.Client~ESRI.ArcGIS.Client.Tasks.Quer...
 query.Where = string.Format("STATE_ABBR = '{0}'", QueryComboBox.SelectedItem);
ChristineZeller
Jennifer,
Very cool!  It is now coming clear and with your help I have the sample working.  I'm still slightly confused on adding another parameter to my query.  I can't seem to get the syntax down would I do something like:
query.Where = string.Format("STATE_ABBR = '{0}'", QueryComboBox.SelectedItem) and MED_AGE < 46;
or would it go up in the initialize like
query.Where = "MED_AGE < 33" and "MED_AGE_M > 32";
Both syntax are giving me errors.
You tired to point me in the right direction with this:
http://forums.arcgis.com/threads/16119-Attribute-Query-on-Muitiple-fields
JenniferNery
Have you used string.Format()? Here's some documentation on how it is used. http://msdn.microsoft.com/en-us/library/system.string.format(v=VS.100).aspx
You can update the Where to the following code:
int min = 32, max = 33;
query.Where = string.Format("STATE_ABBR = '{0}' and MED_AGE < {1}and MED_AGE_M > {2}", QueryComboBox.SelectedItem, min, max);
The best way to test if you are constructing a good SQL Where clause is to try it out on the browser first, by clicking on "Query Layer" link underneath the layer URL.
ChristineZeller
Jennifer,
Thanks a bunch for your help!  I really apprecaite it.....you rock!  I was hoping to ask another question.
So the for loop that is populating the combo box is running on a field that doesn't have unique vales for each record.....in the sdk example it is populating state names and each state has a unique name but I'm populating it with call types and the call types repeat.
So my questing is how can I eliminate duplications  (ex. Call Type = Traffic Stop is listed 15 times in the list and I only want to list it once.
                    TypeDescComboBox.Items.Add(graphic.Attributes["TYPEDESC"].ToString());
thanks
Christine.
JenniferNery
You can use Distinct() from System.Linq and set your ComboBox ItemsSource property, provided that it does not already contain items.
TypeDescComboBox.ItemsSource = (from g in args.FeatureSet.Features
            select g.Attributes["TYPEDESC"]).Distinct();
This is just one way, you can also use a dictionary or list to temporarily hold the attribute values and check whether the attribute value already exist before adding to your ComboBox.
