Binding Map  in Custom control dependency property
727
05-24-2013 04:56 AM
bayramüçüncü
New Contributor III
I wanna a map bindable control to use in MVVM pattern but I have a problem.
I created a class like this.
    public class MapControl : Control
        public static readonly DependencyProperty MapProperty =
            DependencyProperty.RegisterAttached(
            "Map",
            typeof(Map),
            typeof(MapControl),
            new PropertyMetadata(OnMapChanged));
        [Bindable(true)]
        public Map Map
            get { return (Map)GetValue(MapProperty); }
            set { SetValue(MapProperty, value); }
        private static void OnMapChanged(DependencyObject depObject, DependencyPropertyChangedEventArgs e)
And in my ViewModel I created a new Map like this.
    public class MainPageViewModel:INotifyPropertyChanged
        private Map map;
        public MainPageViewModel()
            Map startMap = new Map();
            startMap.Layers.Add(new ArcGISTiledMapServiceLayer { Url = "http://....." });
            Map = startMap;
        public Map Map
            get
                return map;
            set
                map = value;
                OnPropertyChanged("Map");
when I put breakpoints Map object in ViewModel or in Custom MapControl, Everything is working fine.
    <Grid x:Name="LayoutRoot" Background="White" DataContext="{Binding Source={StaticResource ViewModel}}">
        <Grid.ColumnDefinitions>
            <ColumnDefinition/>
            <ColumnDefinition/>
            <ColumnDefinition/>
        </Grid.ColumnDefinitions>
        <esriCustom:MapControl Map="{Binding Map}"  Grid.Column="0">
        </esriCustom:MapControl>
    </Grid>
I finally bind the ViewModel object Map to View MapControl. But nothing is appeared.
DominiqueBroux
Esri Frequent Contributor
I don't see in your code where you put the map in the visual tree.
That might explain why the map doesnt' show up:)
bayramüçüncü
New Contributor III
Where should I placed the Map ? What I should do to appear the map?
