Solved! Go to Solution.
<extendedSymbols:ExtendedLineSymbol x:Key="arrowLineSymbol" Fill="Red" > <extendedSymbols:ExtendedLineSymbol.GeometryTransformer> <extendedSymbols:ArrowPatternTransformer AtEnd="True" /> </extendedSymbols:ExtendedLineSymbol.GeometryTransformer> </extendedSymbols:ExtendedLineSymbol>
<esri:GraphicsLayer> <esri:GraphicsLayer.Renderer> <esri:SimpleRenderer Symbol="{StaticResource arrowLineSymbol}"/> </esri:GraphicsLayer.Renderer> <esri:GraphicsLayer.Graphics > <esri:Graphic> <esri:Polyline > <esri:Polyline.Paths> <esri:PointCollection> <esri:MapPoint X="0" Y="51.399" /> <esri:MapPoint X="2.637" Y="48.865" /> <esri:MapPoint X="12.568" Y="41.706" /> <esri:MapPoint X="13.447" Y="52.483" /> <esri:MapPoint X="21.357" Y="52.160" /> <esri:MapPoint X="30.322" Y="59.845" /> </esri:PointCollection> </esri:Polyline.Paths> </esri:Polyline> </esri:Graphic> </esri:GraphicsLayer.Graphics> </esri:GraphicsLayer>
This sample is done for you.
You need either to include the �??ExtendedSymbols�?? project in your project or just to reference the ExtendedSymbols dll (others projects are not useful)
Then you can create a line symbol that has an arrow at the end with XAML code like:<extendedSymbols:ExtendedLineSymbol x:Key="arrowLineSymbol" Fill="Red" > <extendedSymbols:ExtendedLineSymbol.GeometryTransformer> <extendedSymbols:ArrowPatternTransformer AtEnd="True" /> </extendedSymbols:ExtendedLineSymbol.GeometryTransformer> </extendedSymbols:ExtendedLineSymbol>
(with xmlns:extendedSymbols="clr-namespace:ExtendedSymbols;assembly=ExtendedSymbols")
Then the symbol can be used in replacement of any line symbol.
For example:<esri:GraphicsLayer> <esri:GraphicsLayer.Renderer> <esri:SimpleRenderer Symbol="{StaticResource arrowLineSymbol}"/> </esri:GraphicsLayer.Renderer> <esri:GraphicsLayer.Graphics > <esri:Graphic> <esri:Polyline > <esri:Polyline.Paths> <esri:PointCollection> <esri:MapPoint X="0" Y="51.399" /> <esri:MapPoint X="2.637" Y="48.865" /> <esri:MapPoint X="12.568" Y="41.706" /> <esri:MapPoint X="13.447" Y="52.483" /> <esri:MapPoint X="21.357" Y="52.160" /> <esri:MapPoint X="30.322" Y="59.845" /> </esri:PointCollection> </esri:Polyline.Paths> </esri:Polyline> </esri:Graphic> </esri:GraphicsLayer.Graphics> </esri:GraphicsLayer>
