Drawing a line with arrow in web application with C# and silverlight
1495
6
01-14-2012 11:47 PM
HusseinSayed
Is there any way to draw a line with arrow at the end or the middle in a web application using C# and Silverlight?
DominiqueBroux
Esri Frequent Contributor
You need either to include the ???ExtendedSymbols??? project in your project or just to reference the ExtendedSymbols dll (others projects are not useful)
Then you can create a line symbol that has an arrow at the end with XAML code like:
<extendedSymbols:ExtendedLineSymbol x:Key="arrowLineSymbol" Fill="Red" >   <extendedSymbols:ExtendedLineSymbol.GeometryTransformer>     <extendedSymbols:ArrowPatternTransformer AtEnd="True" />   </extendedSymbols:ExtendedLineSymbol.GeometryTransformer> </extendedSymbols:ExtendedLineSymbol>
(with xmlns:extendedSymbols="clr-namespace:ExtendedSymbols;assembly=ExtendedSymbols")
Then the symbol can be used in replacement of any line symbol.
For example:
 <esri:GraphicsLayer>     <esri:GraphicsLayer.Renderer>         <esri:SimpleRenderer Symbol="{StaticResource arrowLineSymbol}"/>     </esri:GraphicsLayer.Renderer>       <esri:GraphicsLayer.Graphics >          <esri:Graphic>             <esri:Polyline >                 <esri:Polyline.Paths>                     <esri:PointCollection>                         <esri:MapPoint X="0" Y="51.399" />                         <esri:MapPoint X="2.637" Y="48.865" />                         <esri:MapPoint X="12.568" Y="41.706" />                         <esri:MapPoint X="13.447" Y="52.483" />                         <esri:MapPoint X="21.357" Y="52.160" />                         <esri:MapPoint X="30.322" Y="59.845" />                     </esri:PointCollection>                 </esri:Polyline.Paths>             </esri:Polyline>         </esri:Graphic>     </esri:GraphicsLayer.Graphics> </esri:GraphicsLayer>
DominiqueBroux
This sample is done for you.
HusseinSayed
thanx for your help,but i already found this example and trying to find how to use it using points coordinates not by the event handled by the user ,i will be grateful if you can help me
i need to draw lines given their coordinated and i need to keep them on the graphic layer.
DominiqueBroux
For example:
HusseinSayed
You need either to include the �??ExtendedSymbols�?? project in your project or just to reference the ExtendedSymbols dll (others projects are not useful)
For example:
        <esri:Graphic>
            <esri:Polyline >
            </esri:Polyline>
        </esri:Graphic>
Thank you, it works.
MaximPetroshenko
Sorry, I did not find where I can download this library... could you give me a link?
DominiqueBroux
Humm, it seems the portal item was corrupted at some point. I repaired it so now it should work.
