MyDataGrid.FilterSouce = (from g in l.Graphics where g.Attributes.ContainsKey("status") && (string)g.Attributes["status"] == "completed" select g).ToList();
private void FeatureLayer_MouseLeftButtonUp(object sender, GraphicMouseButtonEventArgs args)
FeatureLayer featureLayer = sender as FeatureLayer;
args.Graphic.Select();
args.Graphic.Selected = !args.Graphic.Selected;
if (args.Graphic.Selected)
MyDataGrid.ScrollIntoView(args.Graphic, null);
MyDataGrid. FilterSouce = (from g in l.Graphics
select g).ToList();
var l = MyMap.Layers["Dispatch"] as FeatureLayer;
select g).ToList();
'ESRI.ArcGIS.Client.Toolkit.FeatureDataGrid' does not contain a definition for 'FilterSouce' and no extension method 'FilterSouce' accepting a first argument of type 'ESRI.ArcGIS.Client.Toolkit.FeatureDataGrid' could be found (are you missing a using directive or an assembly reference?)
