Get Center of Polygon Graphic
6598
10
05-09-2011 08:14 AM
deleted-user-ATjHIWsdQYmT
Occasional Contributor III
Stupid question (I think..)
I have a Graphic that is a polygon.  How do I find it's center?  It's easy enough to do with the Geometry's extent using the ".GetCenter" method, but there doesn't seem to be one that exists for polygons.
What I want to do is find the mapPoint for the center of a specific graphic, which happens to be a polygon.
nakulmanocha
Since Polygon is derived from Geometry class. You can always do Polygon.Extent.GetCenter().
Right, but that is not the center(Centroid) of the polygon itself. Instead it is the center of the polygon's extent, or Envelope.
nakulmanocha
If you want the true centroid of the polygon. I would try using a GP service. I haven't tried but I believe Feature To Point GP tool could do the job.
dotMorten_esri
Esri Notable Contributor
The GeometryService is probably a simpler option than GP. Here's an example that does just this:
http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#LabelPoints
LanceCrumbliss
there are probably half a dozen reasons not to do it this way that Morten and Co. can point out, but doing it client-side using the extension method below works for me.  this gets the centroid based on simple 2D euclidean coordinates.  nothing fancy going on at all...
    <Extension()> _
    Public Function GetTruePolygonCenter(ByVal pgnPolygon As Polygon) As MapPoint
        Try
            Dim iNumberOfMapPoints As Integer = 0
            Dim centroidX As Double = 0
            Dim centroidY As Double = 0
            For Each pc As PointCollection In pgnPolygon.Rings
                For Each mp As MapPoint In pc
                    centroidX += mp.X
                    centroidY += mp.Y
                    iNumberOfMapPoints += 1
            Return New MapPoint(centroidX / iNumberOfMapPoints, centroidY / iNumberOfMapPoints, pgnPolygon.SpatialReference)
        Catch ex As Exception
            Return Nothing
        End Try
    End Function
DominiqueBroux
Esri Frequent Contributor
It's depending on what you call 'centroid' and what you are trying to do with it.
If the goal is to place a label on a polygon, the geometry service is the best option since it guarantees that the returned point will be inside the polygon. Nevertheless there is a performance drawback that can be avoided by writing your own code at the client side.
LanceCrumbliss
indeed I do use this to calculate a label position at the center and inside of the polygon. it has yet to fail at that!
even after using it thousands of times, I suppose I should still stress "yet" though.
dotMorten_esri
As far as I can tell, the aboce code calculates the weighted center. There is no guarantee that this is inside the polygon. For instance try it on a polygon shaped like a "C", or a ring with a hole in the center.
LanceCrumbliss
true.  i'm sure there's a way to code that, too.  i suppose it works better than the GetCenter method though since the latter gets the polygon's extent envelope's centoid.
