Getting sub layers from ArcGISDynamicMapservice
874
10-18-2016 05:09 AM
Abdul_Raheem
I have a rest service url which I have used to create dynamic service and added it to the map. I want to loop through the arcgis dynamic map service layer to access feature layers in it.Is there any way to access feature layers in arcgis dynamic layer ?
Abdul_Raheem
I think I have found a solution to my problem. I am using the following to get details of a feature layer from ArcGISDynamicServiceMapLayer and applying the required query definition to it.
ArcGISDynamicMapServiceLayer dynamicLayer=myMap.Layers["myDynamicLayer"] as ArcGISDynamicMapServiceLayer;
string query="";
dynamicLayer.GetDetails(layerID,(ESRI.ArcGIS.Client.FeatuerService.FeatureLayerInfo myFeatureLayer,Exception ex) => {
         if(ex == null)
             query=myFeatureLayer.DefinitionExpression;
             System.Collections.ObjectModel.ObservableCollection<LayerDefination> definitionCollection = new      System.Collections.ObjectModel.ObservableCollection<LayerDefination>();
        LayerDefinition layerDef=new LayerDefinition();
        layerDef.ID=layerID;
       layerDef.Definition=query+" AND Count > 100";
       definitionCollection.Add(layerDef);
       dynamicLayer.LayerDefinitions=definitionCollection;
       dynamicLayer.Refresh();
Source: silverlight api reference
