highlight geometry on mouse over
3918
12
09-07-2010 10:04 AM
AgatinoLa_Rosa
I am looking for a sample code triggering a color change in a polygon feature of a silverlight map control when passing it over with the mouse. Thanks.
JenniferNery
You can use MouseEnter, MouseLeave events on your GraphicsLayer and mark the e.Graphic.Selected to true/false to select/unselect feature as you hover.
If you do not want to affect the feature's selected property, you can add another GraphicsLayer that will always have one feature. In your MouseEnter, MouseLeave event handlers, instead of setting e.Graphic's selected property, you can simply add e.Graphic to the GraphicsLayer you just created. Be sure that this GraphicsLayer provide a different symbol for the graphic so that it can be identified on hover. You may use a renderer or set symbol on the new graphic instance.
dotMorten_esri
Esri Notable Contributor
Use the MouseOver state of the graphic.
See: http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#CustomSymbols
3 of the marker symbols has a hover state defined. This is basically just a storyboard you want to trigger when the user hovers over a graphic.
AgatinoLa_Rosa
I have followed your instructions, however when I set the event such as MouseEnter to the graphiclayer I get the following message.
No overload for 'GraphicsLayer_MouseEnter' matches delegate 'MouseEventHandler
I have also tried to add the handler at the Initialize event
((GraphicsLayer)sender).MouseEnter += new GraphicsLayer.MouseEventHandler(GraphicsLayer_MouseEnter);
but no luck. Any suggestion?
JenniferNery
The better solution would be to define visual states as Morten had suggested.
The MouseEnter, MouseLeave events are on the Map.
AgatinoLa_Rosa
Thanks, it has been helpful the following link: http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#CustomSymbols.
However it takes into consideration only MarkerSymbol. Is there any other example using Fill symbols? I would like also to change fill symbol when hovering a polygon. Thanks.
JMcNeil
Occasional Contributor III
AgatinoLa_Rosa
I have seen that example several times checking on query procedures and never focused on the fill symbol I am looking for. Thank you.
AgatinoLa_Rosa
I am not able to see any symbol for the states - normal, mouseover, selection - defined in the xaml. I am still trying to understand how it works. Following used codes, hopefully I get help.
XAML Code:
       <Grid x:Name="MapLayout" Width="750" Height="600" Margin="0,75,0,0">
            <Grid.Resources>
                <esri:FillSymbol x:Key="ResultsFillSymbol">
                    <esri:FillSymbol.ControlTemplate>
                         <ControlTemplate x:Name="CustomMemberTemplate" >
                        <Grid>
                            <VisualStateManager.VisualStateGroups>
                                <VisualStateGroup x:Name="CommonStates">
                                    <VisualState x:Name="Normal" >
                                        <Storyboard>
                                            <ColorAnimation Storyboard.TargetName="Member"
                                                        Storyboard.TargetProperty="(Fill).(Color)"
                                                            To="#880000FF" Duration="0:0:0.1" />
                                        </Storyboard>
                                    </VisualState>
                                    <VisualState x:Name="MouseOver" >
                                        <Storyboard>
                                                            To="Brown" Duration="0:0:0.1" />
                                        </Storyboard>
                                    </VisualState>
                                    <VisualState x:Name="Selected" >
                                        <Storyboard>
                                                            To="Orange" Duration="0:0:0.1" />
                                        </Storyboard>
                                    </VisualState>
                                </VisualStateGroup>
                            </VisualStateManager.VisualStateGroups>
                        </Grid>
                    </ControlTemplate>
                    </esri:FillSymbol.ControlTemplate>
                </esri:FillSymbol>
            </Grid.Resources>
The cs looks like:
                foreach (Graphic resultingFeature in args.FeatureSet.Features)
                    myGraphicsLayer.Graphics.Add(resultingFeature);
                    resultingFeature.Symbol = (FillSymbol)MapLayout.Resources["ResultsFillSymbol"];
DavidAshton
XAML Code:
            <Grid.Resources>
                        <Grid>
                                        <Storyboard>
                                        </Storyboard>
                                    </VisualState>
                                        <Storyboard>
                                        </Storyboard>
                                    </VisualState>
                                        <Storyboard>
                                        </Storyboard>
                                    </VisualState>
                                </VisualStateGroup>
                        </Grid>
                    </ControlTemplate>
                </esri:FillSymbol>
            </Grid.Resources>
The cs looks like:
Alarosa,
We might be dealing with a similar problem.  I'm trying to make spatial query work for a point layer and I can't get the markersymbol to show up at all.  Maybe if I help you Karma will strike today and I will figure out my problem by solving yours and/or someone like you will help me.  Here's my post if you want to check it out and return the favor if I help.
http://forums.arcgis.com/threads/14622-Super-Easy-Point-Graphic
In the mean time here's what I think I know.
In your code behind C# you have this which is working with your xaml storyboard
The FillSymbol is being passed
  GraphicsLayer graphicsLayer = Map.Layers["MySelectionGraphicsLayer"] as GraphicsLayer;
            if (featureSet != null && featureSet.Features.Count > 0)
                foreach (Graphic feature in featureSet.Features)
                    feature.Symbol = LayoutRoot.Resources["ResultsFillSymbol"] as FillSymbol;
                    graphicsLayer.Graphics.Insert(0, feature);
And then here's your Story for you Fill mouse over and out
                    <ControlTemplate x:Name="CustomPolygonTemplate">
                        <Grid>
                                    <VisualState x:Name="Normal">
                                        <Storyboard>
                                            <ColorAnimation Storyboard.TargetName="Element"
                                                To="#FFF5FF45" Duration="0:0:0.1" />
                                        </Storyboard>
                                    </VisualState>
                                    <VisualState x:Name="MouseOver">
                                        <Storyboard>
                                                To="#8800FFFF" Duration="0:0:0.1" />
                                        </Storyboard>
                                    </VisualState>
                                    <VisualState x:Name="Selected">
                                        <Storyboard>
                                        </Storyboard>
                                    </VisualState>
                                </VisualStateGroup>
                            <Path x:Name="Element" Stroke="Blue" Fill="#880000FF"
                                StrokeStartLineCap="Round" StrokeThickness="2"
                                StrokeLineJoin="Round" StrokeEndLineCap="Round" />
                        </Grid>
                    </ControlTemplate>
            </esri:FillSymbol>
In your xaml you should also have
Default fill or initail, which should look like this mine is yellow
            <esri:FillSymbol x:Key="DefaultFillSymbol" >
                    <ControlTemplate>
                        <Path x:Name="Element" IsHitTestVisible="False" Fill="#66FF0000"
                            Stroke="Red" StrokeThickness="1"/>
                    </ControlTemplate>
            </esri:FillSymbol>
You also need this in your xaml to, in your map declar area   ---- Actually I don't think you need this so don't add this...
 <esri:GraphicsLayer ID="MySelectionGraphicsLayer"
                                    MouseEnter="GraphicsLayer_MouseEnter"
                                    MouseLeave="GraphicsLayer_MouseLeave" />
Oh one more thing in your code behind, under your Public MainPage you need initialize your DefaultFillSymbol
 _drawSurface = new Draw(Map)
                FillSymbol = LayoutRoot.Resources["DefaultFillSymbol"] as FillSymbol
Sorry for all the bad/hack language I barely read code and really haven't mastered the correct terms.
David.
