how to change maximun extent of a map
613
05-26-2012 03:59 PM
YassineEL_JADIDI
hello,
i want to change the maximum extent of my map, how can i do please ?
DominiqueBroux
Esri Frequent Contributor
Not sure what you mean by changing the maximum extent of your map, but if you need to constraint your map extent to a specific extent you can look at this sample : http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#ConstrainExtentBehavior
YassineEL_JADIDI
i want when i click in full extent, map dont exceed my initial extend.
LarryWilliams
Open your map and zoom to the extent you want when you use the Full extent.
Right click on your data frame (usually called "Layer") and select Properties
Select the Data Frame tab
Under "Extent Used By Full Extent Command" select "Other" and click on "Specify Extent..."
Select "Current Visible Extent" and click on OK twice
You've now set your maximum extent.
