When I tried to get initial state of the map as follows
private void setInitialMap()
centerAndZoom(myMap, initCentrPoint, InitMapResolution);
Thread.Sleep(100);
private void centerAndZoom(ESRI.ArcGIS.Client.Map map, ESRI.ArcGIS.Client.Geometry.MapPoint mapPoint, double resolution)
double ratio = 1.0;
if (map.Resolution != 0.0)
ratio = resolution / map.Resolution;
if (ratio == 1.0)
map.PanTo(mapPoint);
else
ESRI.ArcGIS.Client.Geometry.MapPoint mapCenter = map.Extent.GetCenter();
double X = (mapPoint.X - ratio * mapCenter.X) / (1 - ratio);
double Y = (mapPoint.Y - ratio * mapCenter.Y) / (1 - ratio);
map.ZoomToResolution(resolution, new ESRI.ArcGIS.Client.Geometry.MapPoint(X, Y));
the result was negative, as long as I do not put a slight delay 100 ms. What may be the reason?
