Impossible to Zoom on a MapPoint
2517
07-07-2016 08:25 AM
AlexandreMERMOZ
Hi
I'm new on ArcGIS ESRI, so sorry for my question :
I try to zoom on a MapPoint but nothing run. I've try the "CenterAndZoom" method and the ZoomTo(new Envelope(...)).
This is my code :
private void _mapLoad(object sender, RoutedEventArgs e)
            GraphicsLayer gLayer = MyMap.Layers["G_LAYER"] as GraphicsLayer;
            if (gLayer == null)
                gLayer = new GraphicsLayer(){ ID = "gLayer" };
                MyMap.Layers.Add(gLayer);
                Graphic marker = new Graphic();
                marker.Symbol = new SimpleMarkerSymbol();
                gLayer.Graphics.Add(marker);
            MapPoint location = new MapPoint(46.780764, 4.853947000000062, MyMap.SpatialReference);
            gLayer.Graphics[0].Geometry = ESRI.ArcGIS.Client.Bing.Transform.GeographicToWebMercator(location);
            Envelope envFullExtent = gLayer.FullExtent;
            MyMap.ZoomTo(envFullExtent);
            MyMap.PanTo(location);
            //MyMap.ZoomTo(new Envelope(location.X - 100, location.Y - 100, location.X + 100, location.Y + 100));
            //_centerAndZoom(MyMap, location, MyMap.Resolution);
        //private void _centerAndZoom(Map map, MapPoint mapPoint, double resolution)
        //    double ratio = 1.0;
        //    if (map.Resolution != 0.0)
        //        ratio = resolution / map.Resolution;
        //    if (ratio == 1.0)
        //        map.PanTo(mapPoint);
        //    else
        //        MapPoint mapCenter = map.Extent.GetCenter();
        //        double X = (mapPoint.X - ratio * mapCenter.X) / (1 - ratio);
        //        double Y = (mapPoint.Y - ratio * mapCenter.Y) / (1 - ratio);
        //        map.ZoomToResolution(resolution, new MapPoint(X, Y));
With the "CenterAndZoom" method, I have a "NullReferenceException" on the "map.Extent.GetCenter();" (l. 43) and for the "MyMap.ZoomTo(new Envelope(location.X - 100, location.Y - 100, location.X + 100, location.Y + 100));", I have a blank page with my point in the left up corner. For the "ZoomTo" with "PanTo", nothing.
Please, can you bring me your help ?
Thanks to you
ChrisSmith7
I don't have a way to test Silverlight any longer, so I can't test/troubleshoot. But, what happens if you send your MapPoint location to the ZoomTo() method?
By the way, you should seriously contemplate dropping Silverlight ASAP and move to the JSAPI.
AlexandreMERMOZ
Thanks for your reply,
Nothing happens when i send my MapPoint Location to ZoomTo()
And I have test on another project with button (With the sample), and I realize that when i make that :
private void _zoomTo(object sender, RoutedEventArgs e)
     MapPoint PointTest = new MapPoint(100, 100, MyMap.SpatialReference);
     MyMap.PanTo(PointTest);
The result is always on the point 0,0, at the equator (With PanTo and ZoomTo).
I don't very like Silverlight, but I can't do otherwise, it's for my work...
ChrisSmith7
Are you sure your SpatialReference is valid for the coordinates? Can you sandbox in a minimalistic app and reproduce the error, as a sanity check, or maybe try to reverse engineer the culprit, e.g. by slowly adding functionality back until it re-occurs? I know your hands are tied with Silverlight - you should let them know it has been sunseted and, I believe, may already be unsupported by Esri!
AlexandreMERMOZ
Ok, so I think I've understood where is the problem.
When I create a point, I send two parameters in latitude and longitude format, but when I want to zoom or to pan, it's not the same format, and this is the problem.
So, I'm trying to search a way to convert this format into the latitude and longitude format, somebody know if it's possible and how realize it ?
(I don't very understand how SpatialReference work...)
ChrisSmith7
Do you know what the value of SpatialReference is when you debug?
