Is it possible to modify dynamically the ControlTemplate of symbol?
490
12-12-2012 03:35 AM
FabienNAPPA
Re : Hi
Because I don't want to use shadow effect for my custom legend.
Thank you in advance
Fabiano
DominiqueBroux
Esri Frequent Contributor
Yes, Symbol has a 'ControlTemplate' property that can be set with a new control Template.
Though there is no fined grained API allowing to change an existing ControlTemplate. You have to create a new one from scratch.
FabienNAPPA
Hi Dominique,
Thank you for you help.
Should I create a new control that inherits from the class symbol?
Or is that the class SymbolDisplay or SymbolPresenter I can get the all data inside template ?
And after is it posible to explore the content with VisualTreeHelper?
Do you have an example, please ?
Thank you in advance,
Fabiano
