If you check out this example with the 7 day earthquake feed it works just fine. http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#GeoRSSPlug any other GeoRSS feed in there (http://www.openstreetmap.org/traces/rss) and it doesn't work. Debugging it says there is a security issue but I've added my clientaccesspolicy.xml file to my project like suggested on several message boards. The contents are as follows.<?xml version="1.0" encoding="utf-8"?>
<access-policy>
<cross-domain-access>
<policy>
<allow-from http-request-headers="*" >
<domain uri="*"/>
</allow-from>
<grant-to>
<resource path="/" include-subpaths="true"/>
</grant-to>
</policy>
</cross-domain-access>
</access-policy>
Why won't any other GeoRSS feeds work. I've basically copied the aforementioned example line by line. Suggestions are welcome!!! I've attached my code page but basically the method that does all the parsing is this one. #region Parse GeoRSS with Linq
private void RSS(Stream s)
try
GraphicsLayer graphicsLayer = Map.Layers["GeoRSSFeed"] as GraphicsLayer;
graphicsLayer.ClearGraphics();
XDocument doc = XDocument.Load(s);
XNamespace geo = "http://www.w3.org/2003/01/geo/wgs84_pos#";
XNamespace dc = "http://purl.org/dc/elements/1.1/";
var rssGraphics = from rssgraphic in doc.Descendants("item")
select new RssGraphic
Geometry = new MapPoint(
Convert.ToDouble(rssgraphic.Element(geo + "long").Value, System.Globalization.CultureInfo.InvariantCulture),
Convert.ToDouble(rssgraphic.Element(geo + "lat").Value, System.Globalization.CultureInfo.InvariantCulture)),
Symbol = LayoutRoot.Resources["QuakePictureSymbol"] as ESRI.ArcGIS.Client.Symbols.Symbol,
RssAttributes = new Dictionary<string, object>() { { "Title", rssgraphic.Element("title").Value },
{ "Link", rssgraphic.Element("link").Value } }
foreach (RssGraphic rssGraphic in rssGraphics)
rssGraphic.Geometry = _mercator.FromGeographic(rssGraphic.Geometry);
foreach (KeyValuePair<string, object> rssAttribute in rssGraphic.RssAttributes)
rssGraphic.Attributes.Add(rssAttribute.Key, rssAttribute.Value);
graphicsLayer.Graphics.Add((Graphic)rssGraphic);
catch (Exception e)
MessageBox.Show(e.Message);
#endregion
Thanks,Adam Estrada
