OverviewMap more zoomed out
510
09-19-2011 12:57 AM
deleted-user-FIIGSkDYOcdf
Is there any way to make the overviewmap control more zoomed out so it shows much bigger map than the default view.
Thanks
So it is applicable or not?
DominiqueBroux
Esri Frequent Contributor
The min and max ratio scale ratios of the overview map are not publicly exposed.
One workaround is to get the overview source and to modify it.
GarimaVyas
The Overview map doesn't have a way to bind to a custom extent, it automatically picks it up from the map control it is bind to. However, as a way around it, you could use a hidden map control, that does extent calculations from your original map control, on extent changed event handler and you can bind your overview map to that.
A little bit tricky but might work.
XAML:
    <Grid x:Name="LayoutRoot">
        <esri:Map x:Name="MyMap" Extent="-13631774.161,4551117.011,-13629848.904,4552046.199" ExtentChanged="MyMap_ExtentChanged">
            <esri:ArcGISTiledMapServiceLayer ID="TopoLayer"
                    Url="http://services.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer"/>
        </esri:Map>
        <Grid  HorizontalAlignment="Right" VerticalAlignment="Top" Width="300" Height="200" Canvas.ZIndex="100" >
            <Border CornerRadius="0,0,0,10" Background="#BB919191">
                <esri:OverviewMap x:Name="MyOverviewMap"
                                  Margin="8,0,0,8"
                                  Map="{Binding ElementName=MyMap_Ov}">
                    <esri:OverviewMap.Layer>
                        <esri:ArcGISTiledMapServiceLayer ID="StreetLayer"
                            Url="http://services.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer"/>
                    </esri:OverviewMap.Layer>
                </esri:OverviewMap>
            </Border>
        </Grid>
        <esri:Map x:Name="MyMap_Ov">
            <esri:ArcGISTiledMapServiceLayer ID="TopoLayer1"
        </esri:Map>
    </Grid>
XAML.CS
        private void MyMap_ExtentChanged(object sender, ESRI.ArcGIS.Client.ExtentEventArgs e)
            MyMap_Ov.Visibility = System.Windows.Visibility.Collapsed;
            MyMap_Ov.Extent =  MyMap.Extent.Expand(4);
