I loaded an ArcGIS Dynamic Map service that serves as a single layer in my application. There are white edges being added to the features and text making it look really bad. I pulled the map services into ArcMap and it displays them properly.
The imageFormat setting is set for PNG24, I have changed this and tested the other options some are better, some are worse. However, none make the jagged white edges go away.
What do I need to do to make these graphical artifacts go away and make the application display it as it was designed in ArcMap?
I attached a screenshot
