Hi Michele,
> should i ignore the AppStudio version and use the one i installed
Yes, for debugging the app it's better to use the QtCreator that gets installed with Qt5.11.2. Only this QtCretaor will automatically detect the Qt5.11.2 kits.
> why am I getting versions 11 and 12 of the >compilers instead of 15 as in the picture you sent?
Version 12.0 matches Visual Studio 2013. Do you have that version installed. I'm not sure why Qt Creator is not detecting the Visual Studio 2017 installation. Can you try below steps and let me know if MSVC++ Compiler 15.0 gets listed in the QtCreator compiler list?
- Open a command window and execute below command
"C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Professional\\VC\\Auxiliary\\Build\\vcvarsall.bat" amd64
- From the same command window luanch QtCreator by executing the command C:\Qt\Qt5.11.2\Tools\QtCreator\bin\qtcreator.exe
>i am still getting theplugin cannot be loaded for module "Esri.ArcGISRuntime": Impossibile caricare la libreria C:\Qt\Qt5.11.2\5.11.2\msvc2015_64\qml\Esri\ArcGISRuntime\ArcGISRuntimePlugin.dll: Impossibile trovare il modulo specificato.error in Qml Scene
It looks like you used the MSVC2015 kit as the Qt path listed in above error has msvc2015_64 folder reference. Can you test with the MSVC2017 kit as this is the one supported in AppStudio.
Thanks
Shobana
