Path of the photo appear in my app
1050
10-17-2016 06:44 PM
MartinCouture
Hi, I tried many times, but I still have the path of the photo that appear on the top of it in my Quick Report app. I'm following every step of the tutorial, everything works fine execpt this. How I could remove it? Here is the example.
MartinCouture
We found the problem. In QT, under Quick Report/pages folder, in AddPhotoPage.qml make a search to find "debugText" If you search twice you will see a comment to set the debug text visible to false. I have removed the "//" and saved the file. I have uploaded the change to ArcGIS Online. I'm working with AppStudio and everything is now fine.
SathyaPrasad
This is a bug, as you noticed this is purely there to help developers debug the app. This should not have been visible, somehow slipped through. Thanks for pointing it out, we will fix it shortly.
