Hello, Sathya.
Thank you for your efforts to resolve this. However, I rebuilt the App using the cloud-based App Builder (AppStudio for ArcGIS BASIC license), and when submitted the app to the Apple Store for review, the same rejection answer appears:
__________________________________________________
"Jul 3, 2017 at 7:01 PM
From Apple
- 4. 2 Design: Minimum Functionality
Guideline 4.2.1 - Design - Minimum Functionality
Your app has the UIFileSharingEnabled key set to true in the Info.plist, but the Documents folder includes files and folders not intended for file sharing.
Next StepsTo resolve this issue, please move all files that are not intended for user access via the file sharing feature to another part of your app's sandbox. When file sharing is enabled, the entire Documents folder is used for file sharing.
Next StepsIf your app does not require the file sharing feature, please set the UIFileSharingEnabled key in the Info.plist to false."
_______________________________________________________________
I do not what to do... I made a brand new MapTour app with a single MapTour, in which I disabled all sharing options, but the same answer is sent from Apple.
By the way, when I download the App using AppSudio for Desktop, I can see that the EXTERNAL STORAGE capability is by default ON, whilst it needs to be OFF...
The SAME app has absolutely no problem to be uploaded and tested in Android! Can you set the EXTERNAL STORAGE to be OFF by default in the cloub builder for the MapTour Template, as apparently this is a problem for the app to be uploaded to Apple Store?
Regards,
Asparuh
