City Engine color
7038
19
03-08-2013 12:38 AM
chiaramallegni
I need to color with different color each building from one single group using the same rule for each building. I would classified with different color each building following an attribute (value field). How to do? What is the right CGA rule?
Thank's
chiara
MatthiasBuehler1
This should work :
 // Attributes attr Q_GRONDA = "" # string ! attr STANZA = ""   // Functions  red           = "#ffaaaa" green        = "#aaffaa" blue          = "#aaaaff" turquoise   = "#ooebeb" white        = "#ffffff" yellow       = "#ffff73" grey         = "#9c9c9c"   // Start !  @StartRule Lot -->     extrude (float (Q_GRONDA))     Colorizer  Colorizer-->     case STANZA == "4_1" :         color(red)         Continue      case STANZA == "7_2" :         color(yellow)         Continue      case STANZA == "1_3" :         color(blue)         Continue      case STANZA == "4_3" :         color(green)         Continue      else :         color(white)         Continue   Continue -->     comp(f) { side : Facade. | top : roofHip(30,0.5) Roof. }
MatthiasBuehler1
Hi !
What's the attr type ? float ? string ?
let me know .. Matt
ps. this tutorial may help you with the very basics :
http://forums.arcgis.com/threads/53008-GIS-Data-Mini-Tutorial-Building-Height-and-Floor-Splits
chiaramallegni
The attr is string....Thank's a lot!
Chiara
MatthiasBuehler1
I'd try something like this for starters ..
Ok ?
r,g,b = red, green, blue
attr myAttr = "" # point source to object attr ( gis data )
colorFunction(colorChannel) =
    case myAttr == "string_1" :
        case colorChannel == "r" : .3
        case colorChannel == "g" : .4
        else : 0.5 # b
     case myAttr == "string_2" :
        case colorChannel == "r" : .2
        case colorChannel == "g" : .7
        else : 1  #b
    else :
Lot -->
    color (colorFunction("r"),colorFunction("g"),colorFunction("b") )
chiaramallegni
Dear Matthias Buehler,
frist of all thank's for your time.
unfortunatly the code dosn't work, my GIS attr is "STANZA" but there are some errors:
1) colorFunction(colorChannel) =  (mismathched Token)
2) case (mismathched Token).
I I have recently started to work with City Engine and I do not Know many code an low of code.
All the best.
Chiara
MatthiasBuehler1
hi ..
just for information, the above was just an example, without correct code.. that code WILL produce errors.
can you post your code ?
m.
chiaramallegni
I have two different way:
1:
attr Q_GRONDA =0
lot --> extrude (Q_GRONDA)
attr myAttr = "STANZA"
//colorFunction
case myAttr == "4_2" :
else : 0.5 # b
case myAttr == "7_2" :
else : 1 #b
Lot -->
2:
attr Q_GRONDA =0
# color declarations
red = "#ffaaaa"
green = "#aaffaa"
blue = "#aaaaff"
white = "#ffffff"
yellow = "#ffff73"
grey = "#9c9c9c"
attr STANZA = ""
// Functions
attr (STANZA) -->
case STANZA == "4_1" : red
case STANZA == "7_2" : yellow
case STANZA == "1_3" : blue
case STANZA == "4_3" : green
else : white
Where is my error? (attr Q_GRONDA =0 lot --> extrude (Q_GRONDA) is ok! )
MatthiasBuehler1
This should work :
chiaramallegni
Dear Matthias,
Thank's, the code now work. I've modified someting, frist of all attr Q_GRONDA is not string but value (is the height of my building). Now all work but the color of building work in ralation with extrud, I praefer be indipendent each other, but also like this is ok.
I do a master thesis with City Engine, so, can I disturb you other time?
Two other things: you wrote in the previaous code :"top : roofHip(30,0.5) Roof", when I applicate the roof of buildings became from flat to sloping, roofHip(30,0.5) is the code for sloping roof? Wher I can found library with different ty pes of shape like that?
It's possible applicate transparency?
This is my  modyfyed code:
// Attributes
attr Q_GRONDA = 1
attr STANZA = ""
// Functions
red           = "#ffaaaa"
green        = "#aaffaa"
blue          = "#aaaaff"
white        = "#ffffff"
yellow       = "#ffff73"
grey         = "#9c9c9c"
// Start !
@StartRule
Colorizer
Colorizer -->
    case STANZA == "8_1" :
        color(red)
    case STANZA == "7_1" :
        color(yellow)
        comp (f){ side : facade.}
        color(blue)
    case STANZA == "magazzino_2" :
        color(green)
    else :
        color(turquoise)
all the best.
chiara
MatthiasBuehler1
Ciao chiara,
Sure, post more questions here ..
You find other standard roof types and all other CGA operations in the CGA code reference. Go to the Help Menu (F1).
You can make materials transparent by writing :
set (material.opacity, 0.3)
