CityEngine 2016.1 export to LumenRT
3522
15
02-09-2017 05:38 AM
IonutAlixandroae4
Hi guys,
I have noticed that @2016.1 version of CityEngine, there isn`t anymore the option to export to LumenRT directly and I was wondering if the name was replaced by something else (say E-on software VUE? ) or there isn`t anymore this possibility?
If not, the solution would be to export the entire scene as OBJ and import it to LumenRT or to install the LumenRT plugin ?
Thank you,
Ionut
deleted-user-OlpHy1NoMNug
Occasional Contributor II
Where should the plugin be installed?
IonutAlixandroae4
Hi David,
I was confirmed that with this version of plug-in, everything is fine now
Thanks again,
Ionut
AfafAbbas1
Hello David,
I am currently using Esri CityEngine 2016.1.2875 and would like to upgrade to 2017.  Is the new version of LumenRT that works with CE 2017 out yet? I dont want to do the upgrade until this confirmed.
Afaf
DuliniRatnayake1
New Contributor II
Do you know the LumenRT version that works with City Engine 2017.1?
Thank you.
Dulini
ThomasFuchs
Hi Dulini Ratnayake
CE 2017.1 support was just shipped in LumenRT Update 5 (April 15).
There is another update scheduled for June (LumenRT Update 6).
Support for CE 2018.0 will be added to that release.
Thomas F
DuliniRatnayake1
New Contributor II
Thank you Thomas.
I was finally able to install update 5 without any success. I get this error message whenever I try to export a CE model to LumenRT.
I running CE 2017.1 in a win10.
screen capture
Your advise is highly appreciated.
Dulini
